- Apr 11, 2017
- kansas
- Rick
- c20
Hi I am trying to put my 1985 c10 back to 100% stock under the hood. Need a little help I am missing the Vacuum delay valve for the distributor every schematic I look at indicates it is 3 port but no one lists a 3 port for a 1985 c10 they are all 2 or 4 port can someone please verify if theres is a 2/3/or 4 port and what colors it is. I have found out they are color coded like resistors.good to know.. Also please verify if you have a check valve at the efe dist. tvs. On the distributor vac delay valve I am playing with the idea of a tee to the vacuum sources to a 2 port vac delay valve to the dist. thanks
