Mbyoung424
- Feb 13, 2016
- Alexandria, VA
- Matt
- V1500
1987 TBI 305, when cold it'll start after turning over 5-10 times. You can see the oil pressure gauge start increasing and that's when it'll start. Once warm, the gauge doesn't increase and the truck won't start. Putting power to the test lead on the fuel relay starts it up on the 1st or 2nd crank every time. As I understand it, the fuel pressure sending unit by the oil filter supplies the signal to the oil pressure gauge while the oil pressure sensor completes a circuit sending power to the fuel pump from the ECM.
When I got the truck the battery was dead, replaced it, started right up and the next day it was dead again. Turns out the shop that previously worked on it bypassed the oil pressure switch with a paper clip in the connector. I pulled that out, plugged it back onto the oil pressure switch and it started right up, but that's when my issues started.
My first thought was a bad oil pressure switch so I finally replaced it today. Still takes 5-10 cranks to start and then it won't start once warm. I'm going to test the old and new pressure switch in the morning and hopefully I just got unlucky and picked up a bad switch. Problem is, once started it runs fine so I'm at a loss for now. Any other ideas?
