Good headlights
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Hello, I'm looking for some good bright white lights. I cant for the life of me find them. Thanks
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Iowan
Iowa
Calvin
K1500
350 crate
I'm looking for a much brighter than stock white light. but not xeon blue cause I hate it
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Do you have conversion headlights or do you still have the standard sealed beams?
yevgenievich
Viktor
sad
very sad
less sad
9012 bulbs in conversion housing(conversion can be 9006, just use 9012 bulb)
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
I was going to suggest this.
Get headlight relay kits.
Get sealed beam conversion headlights.
Then either put in 9012 lights or 4500k HID's. (you dont have to get blue HID's. Just get a kit that is 3500-5000k)
Crispy
Carbon County, Pennsyltucky
Suburban V1500
X2 for the 9012's.
They just need a little trimming off of the top ear.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
4WDKC I had seen those lights on eBay, but I read some of the reviews though other sites that said the glass is thinner and as a result were somewhat loose in the housing. I went with the Hella conversion lights. I had them on my '79 before. I've only received the high beams so far. I should get the low beams today. I can say that they are a nice quality and fit tightly in the factory housings. I too have already purchased a relay kit with porcelain headlight connectors to deal with the higher wattage bulbs.
Crispy
Suburban V1500
If it matters to anyone else looking into this, the LMC harness doesnt use standard Bosch relays so servicing it down the road will require some wire work.
I would suggest either making your own harness or buying one from ebay for 15-20 bux. The porcelain plugs are supposed to be good for heat resistance.
gmachinz
Harnessworx Inc
Iowa
Jabin
Those porcelain plugs are junk. The OEM 59-series are enough to crack them-they're about as tuff as dried toothpaste imo but yes, they are cheap.
yevgenievich
Viktor
sad
very sad
less sad
Another negative here on lmc harness. Used it but did not like it
shake1969
