- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
Alright. So I just got done doing my first complete brake job, and I had a few post-op questions and concerns. I used NAPA premium shoes and pads. I had my drums turned, and they're perfectly within diameter spec (even with a casting date of October 21st, 1985 and 251,000 miles). I replaced a wheel cylinder from the same date on one side that started leaking and acting up as soon as I started messing with it. I adjusted the star adjusters to where there was just barely resistance on the drums. I buttoned it up and finalized the adjustment with actuating the parking brake and slamming pretty good on them going in reverse. Everything turned out great. The fronts are what worry me. One of the rotors was an aftermarket one, but I'm pretty sure the other one was original. The newer one was well above the thickness spec, but the old one was slightly below after turning. I figured since I generally have conservative braking habits, it would be okay, but if there are problems, I won't hesitate to replace. From what I can tell, the side with the newer rotor sounds fine, but the one with the older one sounds bad...like embarrassingly bad. It sounds like it'll partially touch the pads every rotation and go "shh-shh-shh" depending on speed. I was also wondering about overall front brake noise. Both sides will make a sort of light roar when I hit the brakes moderately. They work very well, and it's not an ugly or alarming noise, but I was just wondering if that was normal on new front brakes. I'm also wondering if I just need to ditch that older front rotor. I spun the rotors after I repacked the bearings and before I installed the calipers, and they were very smooth and fluid-like.
