mpv86dually
- Mar 23, 2017
- Kentucky
- Mark
- c20 converted c30 dually
1986 Suburban c20
I thought at first may just be a cluster grounding issue. First off, when turning on the turn signal the Fuel gauge jerks in unison with the turn signals. It is worse if the lights are on. I was thinking ground issue. Pulled the gauge cluster out and didn't see any direct grounds other than the wires in the cluster harness. However I did find a curious wire that seems to lead to nowhere. On the back of the upper right bulb (facing the cluster from front) There is a terminal that has a lead on it that connects to a nylon insert just above the ash tray, no obvious metal to metal contact anywhere. I don't see this in any schematic (or I just can't find it). end that is circled snaps in the dash above the ashtray.
Thanks,
Mark
Thanks,
Mark
