Dash cluster light issue
SL87Chevy
NC
Sam
My cluster lights were not working due to having issues with not getting power to my Inst Lps fuse but now its fixed. The problem that i cant figure is why its not getting to my cluster. The printed circuit works fine bc if i bridge one line (light green) that has power to a light grey line it works! I've replaced the dimmer switch and all my lights work except the instrument panel. Check my photo, this is the only way I've gotten the lights to work. What is the grey line for? Should it have power (does not when i test it)? Which other colors are supposed to have power bc not all of them do.
Check that the plug for the instrument lighting circuit is correctly seated in one of the fuse block sockets (in the column labeled LPS).
SL87Chevy
NC
Sam
Am i missing something here in that spot?
SL87Chevy
NC
Sam
Is there supposed to be a wire into the lps column?
Yes there should be a plug (with a grey wire) in one of the LPS sockets. That is the feed for the instrument cluster lighting:
Hunt around under the dash - it is probably hanging loose somewhere.
CORVAIRWILD
Uppa US
UGLYTRUK
K2500 Suburban 4x4
Look how nice and uncluttered your fuse box is. When I bought my 1984 Suburban in California 10 years ago, not one single light bulb illuminated. And when I just bought my 1984 K5 Blazer in San Francisco, again not one single dashboard lamp was working, except the heater control. So when I stopped at my friend's junkyard in Colorado, I replaced every bulb with known good used ones, and nothing worked, so I had to polish the brass contacts on the sockets on every single one to get the lights to come on, and that included the high beam and turn signal. Took me 3 hours to get my dash to light up. And I still have one bulb on the far right of the fuel gauge that refuses to cooperate. Curiously, my dash included warning lenses for diesel, and one wire and socket to illuminate said diesel lens. But the truck is definitely a gasser, I am perplexed!
BryantRiverRat
