Anyone running 20x9 with 275's in the front
miky2295
pittsburgh
c10/v20
I'm looking into wheels in the near future and would like a wider tire on the front also. I'd like to do 20x9 front and rear or possibly 20x10 in the rear
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
you can run 275 on a 9....... depending on the tire. All tires are different. My trans am had 275's from the factory.
miky2295
pittsburgh
c10/v20
I wanted to know if anyone was running this size on a sb and what the back spacing was
mbl530
new york
michael
350 ci 375 hp
go online, there are all sorts of calculators out there for wheels/backspacing and offsets, and tires, the tire one will give you height, etc. just fill in the blanks, and it gives you all the info you need, I've been told you can run up to a 315 on the rear with no rubbing.
miky2295
pittsburgh
c10/v20
Was more worried about the front rubbing at 9in wide.i know you can run a wide tire out back just done want the front rubbing on turns. Thank you for the info I'll look into the calculator sites
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
A 305 on a 20 inch x 10 is the widest you can run without clearance issues. Thats what I have and I might have a 1/4" combined clearance inner and outer. You could of course trim the inside lip of the fender, but its still close, esecially if you ever are off camber pulling into an inclined driveway or into a parking lot.
smoothandlow84
Steve
I have 20x8 up front with 295x45x20. I have ample clearance on oem control arms and bagged. Before the truck was bagged, same tires and still had clearance for the front tires. The static drop was 5" front and 9" back. I believe the back spacing is .75 in the front and zero in the back. I can confirm with the shop that I bought the wheels and tires from if need be.
miky2295
pittsburgh
c10/v20
Thank you. If you could find out the measurements that would be great
mbl530
new york
michael
350 ci 375 hp
smoothandlow84, .75 backspacing and 0 backspacing those numbers sound more like offset numbers
iiixtremeiii
