78 K15 Build
Discussion in 'Member Photos' started by Matt Braun, Nov 3, 2017.
  1. Matt Braun
    Matt Braun Supporting Member Supporting Member
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    This is a truck my 16 year old son bought a little over a year ago. He bought it as a snowplowing rig. He picked it up with the plow cheap and felt like he made out good. After using it last winter to plow snow for our residence and a couple clients, my son made enough money to pay for the truck in a season. Fast forward to the summer of 17, when we decided to button some things up and make it a bit more bullet proof for our use. The tranny was starting to slip and the fluid was burnt so we pulled the tranny this summer and had it rebuilt locally but a guy who makes them purpose built for snowplowing. I can't recall what he all did but I know some pump and hard part modifications were done with the standard overhaul. Here's a few pics and some commentary. This will be an ongoing build that will probably stretch into 2018.
    What we bought (plow not in picture)
    A large load of junk to the dump. The box was completely rotten, and one of the dual tanks had a hole in it. We decided to do a TBI conversion in the process, as we struggled last winter with cold starting the old Quadrajet, despite a carb rebuild.
    We stripped the frame down to nothing in put a coat of POR-15 on. So far I like it but we shall see how it holds up to the elements and road salt up here.
    The single exhaust someone put on it was ripped off for a set of dual Hookers. You can see my son mocking up and welding the exhaust.
    78c10bigten likes this.
  2. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    POR-15 on, new exhaust fully installed. Since we were doing a TBI conversion, we updated the tank/pump/sending unit to an 87.
  3. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    Removed rear drums in favor of a disc conversion from TSM. Fit and install were very nice.
    Replaced the rear axle bearings and seals at the same time. One axle bearing came out easy, the other had the outer race dispatched with a die grinder.
  4. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    And lastly, the rats nest formerly known as stock 1991 TBI harness. Got the beast running last night so need to do some final checks and then clean up the engine compartment and harness.
  5. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    We found a Knapheide flatbed for cheap this fall, which will replace the old box. This will be it for the time being, need to have it ready to earn some money.
    Honky Kong jr likes this.
  6. theBIGnaud
    theBIGnaud Full Access Member
    111
    60
    Apr 17, 2017
    California
    First Name:
    Ryan
    Truck Year:
    75
    Truck Model:
    K-10
    Engine Size:
    Vortec 350
    Nice project! Try Evaporust...
  7. 1987 GMC Jimmy
    1987 GMC Jimmy Full Access Member
    20
    2,653
    261
    Jan 23, 2016
    Wesson, MS & NOLA
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Very nice work! Any SES lights or anything fishy with the TBI?
  8. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    As a matter of fact I am working through one right now. When key on, the SES flashes continuously. Truck starts and idles fine, but it cannot be driven (no power). I'm pretty sure its in limp mode. The SES light stops flashing after the truck starts. I'm trying to find another ECM to see if it is a chip or ECM issue. The PROM was just burned by Dave from Old School EFI, so I'm pretty sure that's not the issue.
  9. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    The next phase of this build is replacing the cab. We found this donor cab from a 74 2wd. The current cab is so far gone we're not even going to mess with it. The floor pans had "covers" put over them at one point and so consequently the floors, rockers, cab corners, all floor supports and kick panels are all gone. On this donor cab we are going to replace a lot of it also, but it will be much easier for us to swap this over and still use the truck for snowplowing while we work on the new cab. It looks Classic Parts has every replacement panel we need for the job.
    B.K. Cunningham likes this.
  10. B.K. Cunningham
    B.K. Cunningham Full Access Member
    117
    22
    May 23, 2017
    Spokane, Washington
    First Name:
    Bryan
    Truck Year:
    Truck Model:
    Super Custom 2500
    Engine Size:
    just beware that the hump for the trans is smaller on auto 2wd pickup cabs.
  11. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    Thanks for noting. I didn't realize that, just thought I'd have to cut out a hole for the shifter. Is the hump too small for a 4x4?
  12. B.K. Cunningham
    117
    22
    May 23, 2017
    Spokane, Washington
    First Name:
    Bryan
    Truck Year:
    Truck Model:
    Super Custom 2500
    Engine Size:
    if the cab is a manual, the hump should be the same size as a 4x4 but if its an auto its smaller. I ill try and find the thread that was discussing this.
  13. B.K. Cunningham
    117
    22
    May 23, 2017
    Spokane, Washington
    First Name:
    Bryan
    Truck Year:
    Truck Model:
    Super Custom 2500
    Engine Size:
    low vs high trans hump.
  14. Matt Braun
    80
    32
    Sep 27, 2017
    Bemidji, MN
    First Name:
    Truck Year:
    Truck Model:
    K15
    Engine Size:
    Interesting. And here I thought all SB cabs were the same.
  15. B.K. Cunningham
    117
    22
    May 23, 2017
    Spokane, Washington
    First Name:
    Bryan
    Truck Year:
    Truck Model:
    Super Custom 2500
    Engine Size:
    Yep, as similar as these things are from 73-87 there are so many more differences.
Share This Page
