78 GMC forever build.
Discussion in '2wd Pick-Ups C10 C1500 R10 R1500' started by bluex, Aug 7, 2016.
  1. Snoots
    Snoots Supporting Member Supporting Member
    456
    440
    Jan 23, 2013
    First Name:
    Roger
    Truck Year:
    Truck Model:
    Jimmy Sierra
    Engine Size:
    Hmmm? Should be keyed. Float rod could be bent tho.
  2. bluex
    bluex Full Access Member
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    So if you put the sending unit in the tank correctly it will work.... :doh:
    There are two tabs, and each one goes in a slot. I thought one was just to center it. The hoses should point toward the frame/inside of the truck.
    Snoots and Old77 like this.
  3. Honky Kong jr
    Honky Kong jr Super Sarcastic Man
    45
    12,011
    5,892
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    So it’s happy now?
  4. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Yes an hopefully I'm done messing with gas tanks for a little while.
    Honky Kong jr likes this.
  5. Honky Kong jr
    45
    12,011
    5,892
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Come on it’s fun......NOT!!
  6. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Drove it for over an hour yesterday, it did great and I even got in a few WOT pulls through the gears. I did stall it out again one time but I believe that was my fault and a habit I have from when it was carbed. When your driving and on the throttle the IAC motor "parks" at 30% open. As you slow down and come to a stop the intent is for it to gradually ramp down to idle as you come off the throttle. Well with the manual trans I down shift as I come to stop and I'm off the throttle. If I let the rpms drop enough before I take it out of gear its to far down for the IAC to catch it as it has already started closing while I had the truck in gear and not under throttle. Then it cant open fast enough to save it and it stalls. So I need to change my driving style a little. It possible I can tweak some settings to make it better but honestly it isnt a big deal I just can't coast down in gear under about 11-1200 rpm is all. I probably shouldnt be doing that anyway.
    Db1appel and Old77 like this.
  7. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Made some more tire clearance today. The shocks were holding it up at zero pressure. Without them the a-arm is about 1/4 from the ground. I am going a different direction on the shock mounting though. The top shock mount needs to be roughly even with the top of the frame. I'm going to go with a regular relocator instead of those big mounts I had. I also pulled the front lighting harness for rerouting and new wire loom to get rid of the red crap.
    Old77 likes this.
  8. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Well I had some fitment issues with the second set of relocators that I bought. Details are here:
    http://www.gmsquarebody.com/threads/performance-online-front-shock-relocators.21151/
    After all that mess I go to mount the shocks using the brackets I modified and I would have only gotten about 1" of lift over ride height, if that. After lots of measuring and checking I got them mounted up where they worked the best an give the most travel.....
    Old77 likes this.
  9. Old77
    Old77 Super Moderator Staff Member
    23,268
    360
    First Name:
    Truck Year:
    Truck Model:
    C10 longbed
    Engine Size:
    Love the details accompanied by pics!! Very good info as always :)
  10. bucket
    bucket Super Moderator Staff Member
    36
    14,666
    947
    First Name:
    Truck Year:
    '77, '79, '84, '88
    Truck Model:
    K5, K30, C10, K20 Burb
    Engine Size:
    I'm confused about the stalling. If you aren't letting the RPM drop down below idle, why does the IAC need time to react?
  11. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Anytime your on the throttle over a TPS reading of 3% it "parks" itself at 30% open. Once the TPS drops below 3% and the rpms drop under the setpoint (currently 1750) it starts closing over a 4 second time frame to bring it back down to idle (currently 750). So if I'm running 60 in 5th gear by the time I gear down through 4th, 3rd and 2nd the IAC has fully closed trying to get the engine down to the idle rpm of 750 becasue I'm keeping the rpms up with drivetrain/road speed. Once I stab in the clutch and throw it in neutral there is no load and the rpms drop quickly. Since the IAC is fully closed it stumbles and stalls.
    To be clear this isnt a problem with the unit. Its a problem with some of my settings that I need to work on and adjust to find what works best for it in this application. You would not see this problem at all with an automatic trans and I've actually only had it happen 3 times. There is a procedure in the tuning manual that I havent done yet that is supposed to help correct this and get you to a closer starting point for really dialing it in. It comes setup out of the box more for an automatic.
    I am probably going to lower my idle rpm some to about 650, the rpm where the ramp down starts needs to be lower and as a last step I can make the ramp time longer. That should correct it.
  12. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Played with the settings some an got it much better I can still stall it if I'm not paying attention but I'm going in the right direction. I put about 80 miles on it last night an went to one of our clubs weeknight gatherings...
    Honky Kong jr and Old77 like this.
  13. bluex
    885
    195
    May 9, 2013
    Spartanburg SC
    First Name:
    Truck Year:
    Truck Model:
    C15
    Engine Size:
    Found the clips I needed and got the large trim piece on the gate finally.
    Old77, Snoots and Honky Kong jr like this.
  14. 1973c10
    1973c10 Full Access Member
    1,059
    108
    Sep 25, 2015
    Beaverton Oregon
    First Name:
    Don
    Truck Year:
    Truck Model:
    Engine Size:
    Looks good bud
    bluex likes this.
  15. Snoots
    456
    440
    Jan 23, 2013
    First Name:
    Roger
    Truck Year:
    Truck Model:
    Jimmy Sierra
    Engine Size:
    Got the clips from where?
Share This Page
