78C10BigTen
- Apr 12, 2017
- pennsylvannia
- Ted
- C10 BIG TEN
So my truck originally had cruise with the vac can on the back of the head with the rod to the carb. When the PO added an edelbrock the rod was too short so i took off the vac can. After recently finding a rod long enough i put it all back on. So my question is if the speedo gear in the trans is stripped and the speedo dont work does that in turn make the cruise not work?
