4x4 Suburban
Discussion in '4wd Suburban, Blazer and Jimmy' started by yevgenievich, Aug 24, 2014.
  1. 74 Shortbed
    74 Shortbed Full Access Member
    4,710
    600
    Aug 12, 2013
    Big River, Ca
    First Name:
    Art
    Truck Year:
    Truck Model:
    C-10
    Engine Size:
    350ci/700R to be replaced with a 468ci
    If it's the solenoid just take it apart and rotate the stationary disc 180* and flip the disc over and you have a new solenoid good for another 20yrs, lol..
    Honky Kong jr likes this.
  2. yevgenievich
    yevgenievich Full Access Member
    1,840
    92
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    That was my exact plan. Budget too tight to not save a bit. Back together for now.
    tmp_19182-IMG_20170908_234918792462725.jpg tmp_19182-IMG_20170908_235408444273677.jpg
  3. 74 Shortbed
    4,710
    600
    Aug 12, 2013
    Big River, Ca
    First Name:
    Art
    Truck Year:
    Truck Model:
    C-10
    Engine Size:
    There ya go that works, done it a lot of times, lol..
  4. Honky Kong jr
    Honky Kong jr Super Sarcastic Man
    45
    6,653
    2,254
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Hmm learn something everyday.:waytogo:
  5. 74 Shortbed
    4,710
    600
    Aug 12, 2013
    Big River, Ca
    First Name:
    Art
    Truck Year:
    Truck Model:
    C-10
    Engine Size:
    Anytime I come across a junk starter I grab the solenoid and do that and stick em on the shelf for later use, in fact the one in my truck now is on it's second life going on 3yrs now, lol..
  6. yevgenievich
    1,840
    92
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Had to replace the starter anyway, started to stick when hot. Also found the source of the front exhaust leak. Passenger side exhaust manifold is from a 94 van and does not use the stock gasket when mating to the pipe. Used a graphite gasket material to make one. Appears to seal ok. Started to notice missfire and found two more accel plug wires falling apart. Installed ac delco professional wires and rapid fire spark plugs. The wire lengths from premade wires actually matched within an inch or so of the accell cut to fit wires. Ordered new fuel pump as existing is feeling tires(slow to pump up to pressure) but not installed yet. Also moved the music from the wagon for a day.
    IMG_20171027_212224.jpg IMG_20171027_231539.jpg IMG_20171027_235500.jpg IMG_20171028_113357.jpg
  7. HotRodPC
    HotRodPC Administrator Staff Member
    40,151
    719
    First Name:
    Truck Year:
    Truck Model:
    Silverado K10 to K20 Conversion
    Engine Size:
    6.2 to Gas???
    Damn, 24 pages deep and I'm just seeing this one. You did good though.
  8. HotRodPC
    40,151
    719
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    6.2 to Gas???
    I feel better now, NO, I have seen this one and posted to it before. I just seen page 1. This is the one you combined the white Burb with. :waytogo:
  9. yevgenievich
    1,840
    92
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Probably should seperate the two in two seperate threads. First page is missleading a bit
  10. yevgenievich
    1,840
    92
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Was at offroad park and the fuel pump started diying due to intermittent starvation. Was weak at level as well. Went ahead and replaced it. Biggest pain was setting the tank back up as the bolts are two short to get it back unless everything is perfect. tmp_20067-IMG_20171113_2117211614562209.jpg
    tmp_20067-IMG_20171113_2148051064365200.jpg tmp_20067-IMG_20171113_234637217969663.jpg
Share This Page
