350 swap help
corley.david
US
K10 Silverado
I have a 1985 K10 Silverado that had a 305 in it. I am assuming it was the stock motor as it had very low compression. I purchased a used 350 that came out of a old Chevrolet Winnebago. Ended up being a good low mileage 4 bolt. So got it all cleaned up and put into the truck. The transmission I assume is a 700r4 as it has 16 bolts and MD8 on the side of it. The problem I have is now that it is in the truck and the transmission is mated with the engine, my torque converter/flex plate bolts do not line up. I am assuming that the Winnebago it came out of had a much larger transmission. THe bolts are off by 1/8th of an inch or maybe a little more. I have spun the flywheel all the way around to check each hole. I still have the old stock 305 that I pulled out. Can I use the flex plate/flywheel off the 305? I am confused on the entire internally/externally balanced or how to know if this is something that is going to cause problems. I did notice that on the 305 (old motor) the flex plate has holds partially drilled into it in a straight line. Not sure if this means it is balanced to the engine of just a balanced flexplate. I may be overthinking this but I appreciate any help. Thanks.
gpmorgan
Tupelo Ms.
greg
If both engines have the 2 piece rear main seals, the flex plates should interchange. Lay one on top of the other to double check. I think they both should have 153 teeth. They need to be the same for starter to work. New flexplates aren't very expensive and would be another option.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Unless the camper had a th400 and the 168 tooth and the 6 bolt converter.
74 Shortbed
Gonna have to change the flex plate, one on the 305 should have both bolt patterns so it should work..
corley.david
US
K10 Silverado
What about the balancing issue? If I use the plate off the 305 on the 350 is this gonna cause a balance issue?
corley.david
US
K10 Silverado
Thanks for all the help. I will swap them out and see how it goes.
74 Shortbed
Anytime, let us know how it turns out..
RNFL
