241 with vss
ajd89
Central Michigan
andrew
Have a quick question I'm supposed to pick up a 241 from a 90 k5 tonight and the cluster. I know this is the simplest way to get the vss for a ls swap but the thing I was wondering is do i need the to get the wires with the plugs for the sensor and the cluster or can I repin the cluster wiring and use the plug from the ls donor for the speed sensor?
iiixtremeiii
