diesel_lv
- Oct 17, 2017
- AZ
- John
- K5
1987 blazer, 350, tbi, 700r4. New ACDelco fuel pump, fuel filter, rebuilt throttle body w new pressure regulator spring, tps, iac, engine temp sensor, hei distributor, coil, wires n plugs. All ACDelco parts. Starts fine, idles fine n drives fine. But as soon as I go off road in sand at idle n give it fuel, it starts to cut out like it's running out of fuel. Then if I've been driving n pull into a parking lot at idle, it does the same thing. Does not do it all the time in parking lot, but always in the sand under load. Oh, also has new O2 sensor and did it w and w/out the catalytic. Tps reads .49 at closed throttle. Set iac to idle at 700 in park but had to back screw all the way out then just a turn in to keep throttle blades from sticking. Checked timing chain lash, move 5 degrees on timing pointer before distributor starts to move. Is this too much? I'm at wits end. Ordered aldl cable but won't be here for a week. Any suggestions? Thank you in advance
