Alrighty, i got my 84 gmc last month and its my dream vehicle. But.... I have electrical issues. I dont have any tail lights, no dash lights, with my headlights off my right turn signal works but my left turn signal turns on the hazards and the hazard button pushed in makes all my turn signals and hazard lights stop working. With my headlights on my right turn signal still works but my left turn signal doesnt work at all and neither does my hazards. Needing help so i can get it fixed and legal. Fuses are good and ive checked all the grounds i could find. Thank you for the help.
That's a lot of problems. The best first step in this diagnostic would be ( for me anyway) to completely isolate the rear lighting harness from the rest of the electrical system. You could try just unplugging the rearmost portion of the harness first. Look around up behind the bumper/frame and locate the 4-pin Weather-tite connector that leads to the L&R taillights and plate lights:
Here is what the final section of the harness looks like when it's laid out:
Test the front/dash lighting. Of course you won't have any rear lights, but if things improve you will have a place to start looking for wiring problems.
If the front/dash lighting show no improvement, consider removing the entire rear lighting circuitry - from the firewall back. If you haven't done this before, it may seem drastic but it's actually easy.
Here are the leads that feed the rear lighting circuits. There are only 4.
From the top down, the circuit that they service:
1. LT GRN = Back Up Lights
2. YEL = TS & Brake lights (LH) (both circuits share one filament in the two filament bulb)
3. DK GRN = TS & Brake lights (RH) (share a filament in the dual filament bulb)
4. BRN = Parking, Marker & License Plate Lights
This is the bulkhead harness connector ( the sector with the pins for the rear lighting is traced in yellow):
And this what it plugs into:
There is a 1/4" bolt with a 3/8" head that holds the male plug securely into the female socket. Unscrew it and pull the male plug from the female socket - which will remain securely fastened to the cab side of the firewall.
Continued...
