16 inch rims for my 1977 2500 4x4
giddyupgang0078
Mill Creek In.
Bob
Chevy Scottsdale 2500
Looking for 16 or 17 rims that would work for that year of truck ,concerned about hub size for the lock out
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I ran Mickey Thompson Baja on my 1989 2500 Suburban. Bought them from a guy who had them on 02 Silverado 2500 (so you should be able to run at least up to an 07 Classic 2500 wheel). I know at some point in the last few years GM either changed the bolt pattern slightly or hub size. Maybe both. I dont want to give you wrong info so the best bet is to measure your hub bore with some calipers. I've seen a ton of conflicting info on the web regarding this.
4WDKC
Southern Florida
Kacy
Chevy/GM up to 2010
Ford till 97-99
Dodge till like 2015 (IIRC)
will fit, bolt pattern is 8x6.5
RNFL
