skysurfer
- Oct 23, 2010
- west coast
- John
- 1989 Suburban
- V2500
- 5.7/TH400/NP241C
I'm thinking about swapping my semi-float axle for a full-float. Found one on CL from an '86 Suburban with the 13" drums and 4.10 gears I need. Only concern I have is he lists the wms to wms as 66". I measured my semi-float axle and it's an inch wider at 67". Is that difference because his is from a 2wd and mine is 4wd? I assume it's ok to add 1/2" spacers if the front/rear track difference is noticeable. Are the spring perches all the same distance apart no matter if it's 2wd or 4wd?
Here's the pic he posted.
