14 bolt 9.5?
Ooh ooh, me me me! Lol. I had a 400 once, I liked it. I drilled steam holes into early LT1 heads and all that. Drilling them with a hand drill wasn't all that bad, but finding a bit that could actually drill the holes was a bitch.
I would too, IF I HAD A 400 to use, I'd use it. But this guy is considering sourcing or looking for a 400. IMO, if you don't have one, just stroke a 350. Even when he does find a rebuildable core 400, they can usually only go .030 over and done, where as a 350 you can bore, .020, .030, 040, and even .060. So if you broke a ring hotrodding and scored a cylinder, all is not lost either. I just see many more advantages to a stroked 350 over a 400 for the additional cubes. You're also going to get more rpm out of a stroked 350 with a 5.7 rod vs an OEM short 400 rod. 400's don't scare me, but for this guy here, I'd highly recommend the 383 over the 400 in his situation of not currently having a 400. Besides, when he does fine the 400 someone's going to think they have gold and want a nut and a leg at least below the knee for it.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Is it just the steam holes? What else is there that could prevent you from using something like a set of Vortec heads.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Availability is another line item. I would not feel bad ripping into a 350 and doing things that might otherwise destroy a 400 block, simply because there are not a lot around any more.
I'm thinking Vortec heads on a 400, you better consider what fuel you're going to run cuz the compression ratio is going to be on up there. I'm thinking 87-89 octane isn't going to cut it unless you retard the hell outta the timing.
Yep, I agree with that completely.
Just the steam holes.
Squarehead1984
Tuscola
Tommy
I have a buddy of mine that has a 406 with vortec heads in a Chevy luv. On nitrous it ran a 5.60 something 1/8 mile. That complete engine is now for sale carb to pan. MSD distributer and all. It dynoed 610 on motor I think, solid flat tappet cam.
Squarehead1984
Tuscola
Tommy
Pretty nice truck
And I'll assure you he is not running pump gas. So not a good combo for the street daily driver.
Squarehead1984
Tuscola
Tommy
Yeah you would change the pistons and the cam but you would still have 500hp or better.
Dhatch84
