Engine lift points
Terry Wilkerson
Kansas
Terry
GMC 1500
Are these engine lift points? First pic is the back right second is the front left.
fast 99
Spokane, Washington
2nd picture is a factory lift bracket. Never used them. Usually used an intake carb plate. If your buying one get a plate with 5 lift holes not 3 if you can find it. The 3 hole plate balances the engine but usually having engine front higher is better. I use the second hole on a 5 hole plate.
1lejohn
texas
john
k-1500, 2500 HD
They look like the brackets. I think they would be bolted to the head or block for lifting. I guess technically they are.
GTX63
Tennessee
Ty
Yes, but based on experience I don't consider them optimal. A carb plate gives you better control and the ability to tilt the motor as needed.
Terry Wilkerson
Kansas
Terry
GMC 1500
Tran is out does that make using a chain across diagonally acceptable. Hood is off also. Thing is I need to remove it tomorrow. I think motor is junk had milk shake in the pan.
Carb'ed Vortec 350
Those are perfectly fine to lift an engine, that's all I've used. You'll be okay remove or stab the engine with those and a chain. I have heard good things using the intake plates, just can't bring myself to use one
milk shake in the pan needs context. was it condensation? not worry. was it after running operating temp? yikes
Terry Wilkerson
Kansas
Terry
GMC 1500
Not condensation. It's been consuming coolant. Stopped driving it knowing it has a problem.
fast 99
Spokane, Washington
Best to use 2 chains diagonal crossing each other. Can usually get engines out with one but installation no. What happens when the engine is slid back on the chain to keep it nose high it will be tilted sideways one way or the other. Have use 2 chains many times on fuel injected engines where there is not a carb mounting.
Camar068
10 yrs Air Force
Love the one I got. The screws are kept on the plate and you pull out what you need. Solid and secure to the block.
Nothing wrong with chains, but there's no hunting bolts/washers and setting height of chain when using a block plate.
I would NOT use a plate that bolts where a carb is mounted. Get one that bolts where the intake bolts to the block.
Buy one and done. They aren't expensive considering what you're doing.
also a hoist leveler is nice Ive heard
fast 99
Spokane, Washington
Sometimes people overthink it. Have removed FE Fords, small / big blocks GM, 6.5 diesels with an adapter to Boss 429's with the carb plate. Just did the 429 last week. Never had a problem. Only engine I didn't use a plate on was a 534 Ford. Just be sure the bolts or studs are full depth and tight.
Terry Wilkerson
Kansas
Terry
GMC 1500
It's out. I remover the core support. It will make it easier to install the 6.0 and trans in one piece.
Thanks for all the comments.
loki1978
