TBI to Terminator throttle cable
tackleberry65
Central Indiana
Clay
V3500
I'm installing a Holley Terminator X Max Stealth on my 91 V3500 that was originally a TBI truck. The OEM throttle cable is way too long. Since the Terminator's throttle body is mechanically basically a Holley 4150, is this just as easy as getting a stock replacement cable for a carb truck? I'm running a 4L80e, so there's no need for a TV cable or kickdown or anything. Thinking that I can just get a replacement carb cable from a pre-700R4 era carb truck and run that. That seem right?
Rickf
Grafton NH
1974, 1954 & a 1937
You might try a Lokar cable, it can be cut to the proper length.
consti2tion
East Texas
Cw
C20 Suburban
I used the factory throttle cable on my 86 C20 Suburban with a 454 when I had the Holley Sniper on it. Should be fine for the Terminator as well. (I've since swapped it to a 6.0/4L80E, 454 and Sniper going into my 72 C10.)
MIDWESTCUSTOMS
