Cowl Hood
MtBraun
South Dakota
We knew this was going to be tight, but finding that a stock hood leaves no room for the large air cleaner we need for this build. We want to use an 8" tall element to let the 632 breathe, and when mocking up the stock hood, only have about 2" of room at the front of the air cleaner.
I am not a fan of the cowl hood look on a square, and even then can't find one that is a true cowl hood, they all are a false cowl with the standard hood frame underneath.
Does anyone make a true cowl, or is there an air cleaner option that allows for my limited space? I'm thinking like a modified cold air intake of sorts, but for a carb'd engine. Thanks
2" of room is plenty of room as long as your motor mounts are good. I'd roll on if you don't like cowls.
Fyi, that I'm aware, there are none on the market for these trucks that don't have the OE style underbracing. Ours (AMD) have the OE underbracing, but they have a 14" air cleaner opening IIRC
1lejohn
texas
john
k-1500, 2500 HD
Spectra makes an enclosed housing that has ducts which you run to the stock air inlet openings on the core support. It has a drop-down base. It might be worth looking into.
SquareRoot
There's a reason GM used a snorkel and ducted cool air from the core support. 632 eh? Let's see some pix.
MtBraun
South Dakota
I'll get some pics. In the meantime, I found the USA1 functional cowl hood, but trying to verify the opening measurements. If anyone has this and can measure for me I'd appreciate it. Thanks!
MtBraun
South Dakota
I'll check it out. But we were hoping to keep things as clean as possible in the engine bay.
MtBraun
South Dakota
My 78 had a functional unit in it and I think it was from Harwood. For my other project I picked up one from summit that 2” functional. https://www.summitracing.com/parts/KPT-0851-038
Thanks - could you get me the following measurements: diameter of air cleaner opening, and the distance from the back edge of the hood to the center of the air cleaner opening?
Doppleganger
OH-MI: Just like it sounds
Sounds like a great project. I've got some modded hoods in my future as well.
FWIW, find out what USA1's ACTUAL ETA is on that hood. Everything else they sell as "in stock" is months-years in the waiting.
MtBraun
South Dakota
Well they won't call me back after 3 messages, so they aren't getting the business anyway! But good to know. Good customer service from Carolina Classic Trucks, appears all these functional cowl hoods are made by Key parts.
kkgp81
Kelley
Its currently in storage while I work up from the ground on my K10. I sold that Blazer tub to someone who took a real beating on something that someone hid all the rust on and passed off as a good unit.
78C10BigTen
pennsylvannia
C10 BIG TEN
Carolina classic trucks, is that @bluex ?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I vote keep the GM hood and do a carb “Hat” plumbed for cold air from the front side of the core support.
Second opinion would be hack a hole in the hood for an engine mounted scoop to poke through.
ETA: here’s the cold air setup we built for dad’s car from scraps. There was very little clearance but we made it happen. Car runs much better since.
87POPS
