Spookee
- Nov 4, 2023
- oregon
- hannah and pat
- k10
Hi! We just got our 84 k10 metal baby back from the transmission shop. The 700R4 transmission was rebuilt after the 3-4 clutches went out. They also installed a transgo shift kit and replaced the rear planet, pump slide, new plates and input drum. It has a 24 month / 24k miles warranty now
However we now have a new mystery - when we picked up the truck the mechanic said that there is something going on electrically with the torque converter lockup and they weren't able to figure it out. I don't really understand what it is so I'm hoping to share it here and see what you guys think. Here are the notes I took from our conversation with the mechanic -
The voltage that should be going to the transmission through the brake switch doesn't seem to be the full battery amount (?). they tested the voltage and couldn't find the root cause. Without that working the truck won't go into lockup correctly. So to troubleshoot they ran the electrical straight from the battery/back of the firewall to the transmission. it is internally wired so that lockup will come on in 4th gear. The mechanic said that this should be fine for daily driving. his only concern is that the truck will go into 4th and lockup and that will lug the motor down. He showed us how they wired it in case we want to take it somewhere to undo it in the future (pictures included below).
I'm wondering 1) what could be the potential cause of this electrical issue and 2) could anything go wrong keeping it wired like this. Thanks again for any help I truly appreciate all the knowledge on this site!
