another elco
yevgenievich
Viktor
sad
very sad
less sad
Revisiting the back window again. This time with urethane primer and no chrome trim. Just filled the gap with urethane and will paint up to it.
yevgenievich
Viktor
sad
very sad
less sad
Water pump replacement. It was threatening to throw fan in to the radiator. Did not leak, but sounded like the whole thing was about to fall apart.
yevgenievich
Viktor
sad
very sad
less sad
New intake showed up. But down on funds and time. Need to find some pistons in specific weight range and a bunch of misc pieces. For now quadrajet is doing just fine, so this is more of a getting ready if and when current set up acts up
yevgenievich
Viktor
sad
very sad
less sad
Slight rant. The large radiotor from champion did not hold out long enought for engine changes to be implemented. Started leaking few months ago and finally pulled it out. Unfortunately they have lifetime warranty but not for scratch sale parts(i had the dented discount) . Definitely not worth the savings there to loose warranty. Tried to see if can make the radiator from the camaro fit, but it is not wide enough unless I loose the shroud. Not sure yet on pathway. Might still modify mounts to run 4 core from 1st gen f body and mount electric fans from 4th gen f body. Will need separate trans cooler as well. Or give in and drop money in for another radiator. Avoiding champion i guess.
theshawnR
