Car hauler issues. How can I fix this. I dont know trailer parts.
Nasty-LSX
TogetherforeverCovid19
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
So I have ignored my 83x18 classic car hauler for the past 10 years. I have always needed
a tongue storage box. I have lost many ratchet straps and axle straps because they can never
be in one space. I had a 10k smitty built winch that I only used 8 times till it took a dump.
Dont buy smittybuilt products, they wont sell you parts when you need them. So I told myself
I would buy a WARN, so I bought a 12K and dont have to worry about it breaking down.
Long story short, I got a storage box for the straps and battery for winch. The leg ( I know I said that wrong LOL)
that holds the front or tongue up will hit the bottom of the box and will not lock. It spins upward and locks in place. I was going to cut the foot off and just use a 2x4 piece of wood like in the pic to set it on. But If I can replace that whole piece with a better
one I will. I was told they sell some you can even use a drill to lift and lower so no handle to spin. Whats that
leg called? Let hear your upgrade opinions. I need this box on here. Thanks.
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Or I might just cut that back half of that foot off.
that is called a trailer jack
You can mount one either on the outside part of the A frame that bolts on oir you can weld a new plate to either forward more or on the outside. if you do this i highly recommend getting a nicer jack. if you want to have it jacked up with a car on itm youll appreciate a nicer one
KCKKen
Kansas City, Kansas
Ken
1500/C20
Make your foot plate where it will pin on the bottom of your jack.
Like this:
The added plus to this is you could add some length to it and eliminate the piece of wood you have to use under it.
I have a tongue jack on my trailer like that, I was able to get the snap ring off and work on the jack itself, then reinstall it once I was done.
Take Care,
KS in KCK
Washington
Good thing is you don’t have car hauler issues, you just mounted a toolbox in the way of the tongue jack.
All good advice so far. Depending how you want to use the jack and how often.
Do you want/need to keep it centered and heavy duty for unhooking with tongue weight still on the trailer?
Can you get by with just welding on a new mounting ring elsewhere and move the jack?
Electric Jack wanted? or just get a drill attachment and do away with the handle. Cut the foot off, buy one that is removeable, drill a couple holes and done.
Easiest solution imo is the last one.
$14.99 drill attachment
$14.99 jack foot. Could even get fancy and get a longer one to adjust height.
Done. No need to move the exiting jack for well under $50 and about 30min of your time.
Nasty-LSX
HOUSON TX
Mi Hung Lo
c10/k10/k20
LSX
Thanks man!! The jack is in the position where it is as far up (forward) as it can be placed. Any further forward
it would not be able to tilt completely and lock in position. I could put a removable foot on it. I think it wont hurt to just cut the back half of the foot off. I found a drill operated head for the jack. But $200 is not worth it for me as I barley use the trailer LOL.
Im going to see If this can be mounted up front at the A frame area. I like this better and do away with the swivel jack
Dryriver1
Robert
350 cid, 5.7
Washington
I thought there was just a drill attachment you could just attach if you remove the handle. They’re cheap. But I’d think it would only work with light weights without tearing the drill out of your hands.
Cutting the foot off won’t hurt anything either.
You can always mount the jack to the outside of the A frame and then it can be further forward if needed.
Or the new one you posted will work. Take a little fab work I suppose.
There’s many options.
krogers98gmc
