- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
In the process of removing the heater control knobs on my 79, I managed to snap the pot metal piece that formed the lever for the heater/defrost. A quick look in the catalogs showed this part is not readily available so I decided to repair it. What did I have to lose?
As can be here in the picture there is a raised surface, this needs to be flattened.
I took some 16(?) gauge sheet metal and cut out a new arm and formed it on the belt sander, this could be done with a bench, angle, or die grinder.
Using a 3 inch cutoff wheel mounted in a cordless drill I carefully ground the area smooth, I kept the drill to very slow speeds to prevent breaking this further.
All flat and I cleaned the rear up to help adhesion.
