Starter fried
Boltrunner
Odin mn
Shane
V20
Yesterday i was using the blue bomb to pull a post pounder and everything was going as good as it could untill i turned it off to take a break. Went to start it and i wouldnt even get a click. Pull started fine though. Pulled the starter off and tested it. Its toast. Perfect time to get a mini starter i figure. Ive read that the starters for the newer s10 is the best way to do it cheaply. Do i need different bolts? And is there anything else to take into consideration?
Boltrunner
Odin mn
Shane
V20
78C10BigTen
pennsylvannia
C10 BIG TEN
Thanks. After pricing a starter at the parts store i was just gonna go through summit. But this is definitely the way im gonna go. What sucks is i leave for work on Monday so im gonna have to wait to install it. But at least it will be waiting for me when i get home.
I came upon it here on gmsb but i never bought one. Let me know how it works because i bookmarked it so i could get one.
78C10BigTen
pennsylvannia
C10 BIG TEN
Its too bad your in SD i have a used one from my ol 350 id sell ya cheap but shipping would probly hurt.
Had one for ya too. Hate the distance.
IT'S 2018!!! WHERE THE HELL IS MY FLYING CAR!?
Just put one in my '73. $21 bucks at pull a part and works like a champ! Mounting bolts are shorter for the mini tho. Glad I snagged those too.
Be sure you get bolts with the 'crosshatch' pattern on them or, you can drill the head for safety wire.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Hmm, there’s a guy in my hometown who rebuilds starters and alternators that’ll last indefinitely so I’ll keep my big ole direct drive starters and Delcotron alternators as long as I’ve got someone to tinker on them and do a good job. The gear reduction ones are cool, though.
Camar068
10 yrs Air Force
I know there are pix up that show the contrast between 'old style' and mini-starters and have read about the mounting bolt differences.
You'll notice a hole in the upper bolt. There's one inn the lower one too. I drilled those for safety wire.
5" = old style
4 - 5/8" = mini
Here's a pic for reference . . .
Chet1
Austin. TX
Sierra Classic
Chet1
Austin. TX
Sierra Classic
bman1985
Maryland
Brendon
c1500
Yeah those cheap starters are garbage. I got the acdelco brand for a 1995 tahoe from rockauto. High quality and reliable. Get the bolts too
RNFL
