10 bolt corporate axle seal advice
Sublime
usa
m
Looks like I will be changing front axle seals in the near future. The passenger side is leaking gear oil. Any tips? It looks like the ring gear assy. has to be removed, I have never messed with gears. Will it be OK if I remove the ring gear assembly and reinstall?
Thanks
yevgenievich
Viktor
sad
very sad
less sad
Correct and it is ok to do so. I went through mine not long ago. New seals, ujoints, ball joints, wheel bearings, wheels bearing seal.
Everything is relatively straight forward, just everything has to come a part to get those seals. Good time to replace the ball joints.
Thanks
Sublime
usa
m
That's good news, thank you
rossivey
