- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s; 65-C20 with 4:57 gears and Borg Warner Overdrive
- Carb'ed Vortec 350; 1972 L48 350
Sucks he sold it, you would have liked that setup. Crusty Biscuit has that setup and as much as I want to put the sm420 in the truck, I just can't do it yet because the 3-on-the-tree is fun to drive and also is a theft deterrent. Mine has the BW Overdrive in it, so the 4.57's become 3.19's in OD. Roughly 2400 rpm to cruise 70 mph, and 3000 rpm is 86 mph. The suckers are loud, can definitely hear the gears while driving around.
@MikeB I think the tranny gear ratios depended upon the rear end gearing. I have two three speeds and each came out of 3/4 ton trucks and each has no grooves in the input shaft. I know Crusty Biscuit has 4.57's but my other 3/4 ton I'm not sure because I haven't popped the cover to inspect the ring gear for the stamped numbers.
