Fitech
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I've read a lot about people using the Bosch 044 pump but it's money, $227 on Summit. If you look into it and think you found a good deal on one make sure it's not a Chinese knockoff, I also read about a lot of people getting ripped off that way when the pump dies prematurely.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
You could run a command center too.
Burban
Bear
Uranus
H
Suburban
A) it's $250 more
B) heard bad things about pulse modulated fuel supply, a return line seems a safer bet.
Course, I could be wrong.
Oh and it's a needle and seat thing, that doesn't do well with inclines.
bluex
Spartanburg SC
C15
Is there a model I can pull one off that will fit?
87+ tank so its baffled for efi. 87 model sending unit to fit the tank. 96 model pump on the sending unit. Then you can adapt the sending unit fittings to AN if you want. Same setup guys use to LS swap....
gpmorgan
Tupelo Ms.
greg
I've heard the in line pumps are pretty noisy unless well isolated. I have an aeromotive intank pump that's very quiet and costs around 100 bucks.
yevgenievich
Viktor
sad
very sad
less sad
I ran external pump before on my TA. Was happy when intank filter sock clogged and took the chance to install intank pump. Generally pump doea not like to pull fuel, so it needs to be below the fuel level, and then it can still get a bit hot.
