Suburban Frames
ChooChooC20
US
Justin
I have a 1986 c20 suburban and want to make it 4wd and was wondering if a 1980 4wd suburban frame will fit correctly under the 1986 c20 suburban
Sent from my XT1056 using Tapatalk
Yeah, but you will need to use the body mounts from the '80 model and not the '86.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The issue of the 4x4 trans tunnel being taller also comes to mind. People have said, though, that this can be mitigated with a small body lift. If it were me, I'd just find a junk K-Suburban and cut the tunnel out.
Moved to a more appropriate subforum :waytogo:
BryantRiverRat
