86 K10 5.3 swap
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
oh.....nice and slim. Gonna play with the tail light idea I mentioned above tomorrow.
You could probably fit 4 of these under the carpet under the seat.
Camar068
10 yrs Air Force
lol that's why I use the edit button......sometimes too much though.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yea I go back and try and fix stuff too. But if it's quoted it stays butchered.
Camar068
10 yrs Air Force
update on the tail light fuel fill. I created a plate to mount to the back of the tail light. Man was it a bitch to cut. The metal wanted to jump/move with the jigsaw blade. I'm sure it's lack of tools and technique. I gave up on that pretty quick....well after 4 jigsaw blades.
I decided to use 1" wide steel to run between the right side screws. Then drilled holes for the hinge "fingers" to bolt to. I need to support the left side as the tail light flexes away from the hinge easily. If it wasn't for the side marker bulb, I would have mounted it on the left side like @Mr Clean did.
The right side does stick out a bit, the bottom right screw/nut is hitting the original hole. I'll either delete that hole or maybe bend it in.
I used a Jeep Grand Cherokee hinge, around a 07. That's how I got mine to mount on the left side.
Camar068
10 yrs Air Force
yeh but your tail light didnt have a bulb on the left side of the tail light. Had to improvise. Under the top bulb (behind the hinge arm is another bulb). Thanks for the pics n such on yours.
Camar068
10 yrs Air Force
Got it down to a list now:
1. Mount fuel tank (under bed), filter, run lines and power (Frame work ready for tank already)
1A. Figure out fuel filler and hoses (preferably able to have fill pointed to the rear).
2. Little more prep on the fuse box
3. Power steering hoses (if needed)
4. temp fuel cell to test engine on test stand
5. Build Air intake line
6. Block off EGR
7. Brake booster fitting on intake
8. Bolts for throttle body.....damn bolt Gnomes stole 'em
9. have steam line adapter installed on to current radiator
10. solder TAC to Pedal harness back together
11. Find location to drill hole in cab for TAC/Pedal harness
I'm sure there's some missing. I'll research more and prolly stop by B&K in Barbourville to discuss.
Camar068
10 yrs Air Force
Reference for steering pump hose copied over from what have you done.....thread.
You dont need custom hoses, just remove the fitting from the rear of your stock pump and place it in the LS power steering pump. Then you can use a stock replacement hose....
Awesome. I'm going to copy this over to my thread so it's easier for me to find lol.
Camar068
10 yrs Air Force
little toying tonight. I wanted to block off the EVAP solenoid hole, but couldn't bring myself to pay $15 for a screw and plate lol. A 308 and 44 Mag shell fit fine. I chose the 44 mag due to it having a lip to help stop it getting sucked into the engine. Probably tape off the shell and paint the rest. Had to change the camera angle to read the shell due to lighting. Slap some silicon on it or rubber gasket and call it done. Soldering brass to steel is not easy by the way LOL.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
See stubbornness does lead to ingenuity.......and the bullet made a hole and the shell casing filled a hole.:cheers:
Azathoth
W TN
Ed
Camar068
10 yrs Air Force
Thanks for the link. Someone over there mentioned the Duramax pedal as well.
Jakebr8k
