74 Shortbed
- Aug 12, 2013
Maybe maybe not, there was no pressure because the pump wasn't engaged so it couldn't pump fluid, as long as you didn't run it long you may be ok, and as long as the converter wasn't jammed hard against the pump gear, I would slide the tranny back and slide the converter in right and hook it back up and try it got nothing to lose, I did that with my neighbors car and it worked..
