Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance > TBI & EFI Conversions
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 02-22-2011, 01:41 PM   #1
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default '89 350 TBI Motor Accesory Bracket Mounting Bolt Locations
While I had the water pump out and the fan, I decided to take advantage of the situation and see how these damn accessory brackets are installed on the motor and where the bolts are hidden using the digital camera.
Here is the pass side bracket that holds the A/C compressor. Looks like two on head and one on the bottom of the block. You can see the one on the head on the right side is a stud with a nut. These all looked like 9/16" to me.
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 02-22-2011, 01:51 PM   #2
89Suburban's Avatar
Model: R-1500
Default
Here is the drivers side bracket that holds the alternator and P/S pump.
This looks like it has 3 bolts going into the head and one on the bottom of the block.
Note the one behind the power steering pump.
__________________
Old 02-22-2011, 01:55 PM   #3
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Swims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to behold
Default
wow you got the alum. brackets on yours. My 88 tbi newer body style truck has the steel horseshoe bracket. it weighs a ton and was only on 88-90 or so I heard, and I guesssome 89 and 90's got the alum. ones.
Mine has about the same amount of bolts, 2 on each side on bottom, 2 in each head maybe more, some are studs and some are bolts in the heads, then a bracket behind the PS pump, several support bars up to, and that's about it I think.
__________________
FINALLY in a GMSB
Swims350 is offline   Reply With Quote
Old 02-22-2011, 02:37 PM   #4
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Nice to know info for when and if the time comes . Thanks Dawg !!!
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 07-27-2011, 02:15 PM   #5
4x4chvy
Year: 1987
Model: K5
Engine: 350
4x4chvy is on a distinguished road
Default '87 K5 TBI Engine Bracket Pics (Steel brackets)
My truck is a little different. 1987, TBI 350, with ac and steel brackets.
4x4chvy is offline   Reply With Quote
Old 07-27-2011, 02:17 PM   #6
89Suburban's Avatar
Model: R-1500
Default
Plus your alternator and compressor are on oppisite sides that mine are.
__________________
Old 07-27-2011, 02:18 PM   #7
89Suburban's Avatar
Model: R-1500
Default
And you don;t have the reverse rotation water pump.
__________________
Old 07-27-2011, 07:34 PM   #8
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Default
the steel horseshoe setu didn't show up along with reverse rotation water pumps to match and serp. setups til 88, then in 89 or 90 they changed to burbs style, all alum. my 88 tbi truck has the steel horseshow bracket setup for serp.
__________________
FINALLY in a GMSB
Old 08-04-2011, 12:55 AM   #9
Mryantibbz
Year: 1988
Model: 1500
Engine: 5.7
Mryantibbz is on a distinguished road
Default
What would i be able to replace the air conditioning bracket with? i took the air conditioning out and the bracket has the tentioner and i cant just completely eliminate it. Or what kind of belt could i use without the tentioner. Any help would be appreciated.
Mryantibbz is offline   Reply With Quote
Old 08-04-2011, 01:48 AM   #10
f1shman's Avatar
f1shman
Senior Member
Year: .
Model: .
Engine: .
f1shman is on a distinguished road
Default
Welcome to the site Mitch. I'm going to assume you are talking about the aluminum bracket serpentine system that 89Sub posted pictures of originally.
Dorman #34152
You can get it online or thru most parts stores.
f1shman is offline   Reply With Quote
Old 08-04-2011, 08:51 AM   #11
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Default
yes either an a/c bypass pulley, or if you have the steel horseshoe bracket like mine, they have a different bracket you use to eliminate a/c but it's hard to find, meaning junkyards or online from a person who has one only.
__________________
FINALLY in a GMSB
Old 08-04-2011, 04:39 PM   #12
89Suburban's Avatar
Model: R-1500
Default
Dorman #34152
Sorry I didn;t reply Mitch, but I had no info to give, and it is also a mod I want to do to my truck to eliminate the compressor. Thanks for the help fishman. What about the belt size? Does it stay the same?
__________________
Old 08-04-2011, 04:42 PM   #13
89Suburban's Avatar
Model: R-1500
Default
I googled it real quick, seems like the cheapest place is Jeggs, even cheaper thatn rockauto. I really want to get this.
http://www.google.com/webhp?sa=N&hl=...w=1272&bih=244
__________________
Old 08-04-2011, 04:46 PM   #14
f1shman's Avatar
f1shman
Senior Member
Year: .
Model: .
Engine: .
Default
Belt size and routing remains the same as long as you are just swapping out the compressor for the pulley. If you are making other changes at the same time (deleting a smog pump for example) then you would have to change things up.
Going thru your link, Amazon has it for $27.49 with free shipping. Might be cheaper in the long run.
Old 08-04-2011, 05:45 PM   #15
89Suburban's Avatar
Model: R-1500
Default
Yah, I forgot about the shipping, good point.
I am glad about the belt, this is one mod I will absoloutley be doing over in the fall.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
14 Bolt FF 4.10 Open Differential HotRodPC Differential & Driveline 44 02-28-2013 10:17 AM
Pulling a motor... 89Suburban Engine & Performance 67 02-18-2011 01:31 AM
1988 Chevy K5 blazer and motor issue Pervis TBI & EFI Conversions 46 01-17-2011 08:48 PM
Review: Wheel Bolt Pattern Gauges davbell22602 Garage 2 01-16-2011 08:50 PM
75 Pontiac 400 Motor with Heads HotRodPC For Sale 5 12-29-2010 05:43 PM
