Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Engine & Performance Engines, Engine mods, Chips, Filters, etc.
User Tag List
Reply
Thread Tools Display Modes
Old 02-15-2011, 11:32 PM   #1
davbell22602's Avatar
davbell22602
Senior Member
Year: I Dont
Model: Have
Engine: One
davbell22602 is on a distinguished road
Send a message via Yahoo to davbell22602
Default Post experiences on removing exhaust manifold studs
I wanna hear some of your good and bad experiences when removing exhaust manifold bolts. From broken bolts to worn rounded off heads, etc.
I average person would pay a exhaust shop the drill them out and redrill the holes.
Well I broke one and had one where the head was worn where I couldnt a perfect fit socket on it.
davbell22602 is offline   Reply With Quote
Old 02-15-2011, 11:35 PM   #2
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Are you talking the bolts to the head, or are you talking the studs where the donut flange or gasket meets the head pipe?
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 02-15-2011, 11:37 PM   #3
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
Once upon a time...
[Insert every explicative you know here]
The End.
LOL but seriously I've had to drill/tap them when they break off even, or cut the head off if it rounds off. At least if it rounds off, once you get the manifold off you can put a pipe wrench on it and usually get it out. I haven't had these problems since I started running headers.
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Old 02-15-2011, 11:39 PM   #4
davbell22602
Senior Member
Year: I Dont
Model: Have
Engine: One
Default
The studs you see on the outside that go into the head.
Old 02-15-2011, 11:44 PM   #5
Irishman999's Avatar
Irishman999
Senior Member
Year: 1985
Model: K-1500 High Sierra
Engine: 305
Irishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant future
Default
Im currently driving around with a broken stud in my manifold where it bolts to the pipe. Shit just snapped off, If I remember right its before I got a can of pb blaster and tried busting it loose with nothing on it. Snapped right off.
__________________
Member #10.
Proud of my big dumbo mirrors
RetroC10sport: "Yeah, and if my aunt had a dick, she'd be my uncle." Got in my blazer and drove off.
RetroC10sport: "I know a gurl that looks like that...She has a bigger dick than you do."
Irishman999 is offline   Reply With Quote
Old 02-15-2011, 11:46 PM   #6
HotRodPC's Avatar
Year: 85
Default
Originally Posted by crazy4offroad View Post
Once upon a time...
The End.
That's right. You hope if you break it, when you get the rest off you have at least a nub to get ahold of with a small pipe wrecnh, and I have had great success with curved jaw Vise Grips in good shape where the jaw teeth would dig into the bolt or stud and get a good bite on it. And of course you have sprayed some kind of WD-40, trans fluid or PB Blater. A little heat can help sometimes too.
The real trick I find that works, once you have a good bite on it with a pipe wrench or Vise Grip, don't be afraid to go forward either as if tighening it once the bolt or stud has broke. Work it back and forth adding a bit of your spray a couple times as you do this. Just keep working it loosen and tighten, going more to the loosen direction each time. It knocks off the rust and allows it move around instead of keep jamming up in the threads and trashing your threads. Then when you get it out, chase it with a tap and spray to make sure you got all the crap out the hole. That is my best advice and I know it works. As far as breaking it off at the surface. SOL, drill it is only option.
__________________
UNDER CONSTRUCTION
Old 02-15-2011, 11:50 PM   #7
davbell22602
Senior Member
Year: I Dont
Model: Have
Engine: One
Default
I was told to never use torch on the studs cause it can ruin the head. Also I was told to try to remove the studs by spraying pb blaster on them, then run the engine til hot, and try taking them out while the engine is hot.
Old 02-15-2011, 11:52 PM   #8
HotRodPC's Avatar
Year: 85
Default
I've got a broken exhaust manifold bolt on the Box Van. Its a 460 motor crammed into a Van. How much room do you think I have to fix that??? NONE. It also happens to be the bolt that bolts the oil dipstick to the side of the motor, so my dipstick kinda floats around doing its own thing now. Actually not alot of room for it to travel very far and do any damange, but I did zip tie it to a hose to hold it in place. Its not leaking yet. Its the far front exhaust manifold bolt to the head. I am hoping it lasts that way until I ever need to pull the motor, but I hope that's not anytime soon either.
__________________
UNDER CONSTRUCTION
Old 02-15-2011, 11:52 PM   #9
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Swims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to behold
Default
we actually have a stud extractor works great on broke bolts. or vice grips/locking pliers, or pipe wrench.
I've removed manifolds on4 vehicles that I can think of right off, all of them came out perfect. I used an impact on dad's 86 k10, not sure on his 84, on mine I used a ratchet.
On the bottom side I always impact, all of them, and almost ALWAYS have one or more break. I had a couple break on mine, then I tried to get the studs out of the manifold and they broke, I got maybe 2 or 3 studs out in tact not broken. The block side I always had good luck with though.
__________________
FINALLY in a GMSB
Swims350 is offline   Reply With Quote
Old 02-15-2011, 11:53 PM   #10
HotRodPC's Avatar
Year: 85
Default
Originally Posted by davbell22602 View Post
I was told to never use on the studs cause it can ruin the head. Also I was told to try to remove the studs by spraying pb blaster on them, then run the engine til hot, and try taking them out while the engine is hot.
That's the same as adding heat and should work well too.
__________________
UNDER CONSTRUCTION
Old 02-15-2011, 11:57 PM   #11
HotRodPC's Avatar
Year: 85
Default
Personally, I don't know why auto manufactuers just don't use brass bolts for exhaust manifolds to the head and for the head pipe flanges. Brass is soft, it will give way instead of break. Also does not corode or rust near as bad as steel. I alwasy use brass nuts on exhaust studs. It keeps the studs in good shape. But I too have got sick of manifold stud problems and gone to headers on a couple vehicles. Sucks replacing header gaskets occasionally, but at least the bolts hold up and don't break.
__________________
UNDER CONSTRUCTION
Old 02-16-2011, 01:33 AM   #12
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
How am I supposed to attack head gaskets by myself reading this shit? I may as well cough up the extra dough to pay someone else to do it.
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 02-16-2011, 01:45 AM   #13
RetroC10Sport's Avatar
RetroC10Sport
Year: 1967, 1989, 1991, 1991; 1995; 2005
Model: Ford Mustang; GMC Sierra C1500 SportSide, GMC Syclone; Chevy S10 Blazer, Olds Silhouette; Corvette
Engine: 200 L6; 5.7, 4.3, 4.3, 3.8, 6.0
RetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond repute
Default
I think every service manual should have this.
__________________
"We're gonna get ourselves a cheap lawyer!"
RetroC10Sport is offline   Reply With Quote
Old 02-16-2011, 03:00 AM   #14
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
You can do it man. I changed out heads on A 460 ford at the age of 16 for a neighbor, only special tool you need is the torque wrench.
__________________
Member #10.
Old 02-16-2011, 03:06 AM   #15
RetroC10Sport
Default
Be brave. We're right here to help ridicule you!
I'm kidding. You know we'll be here to help with any questions you have.
__________________
Reply
Bookmarks
Tags
bolt extraction, custom exhaust, exhaust manifold, manifold studs, pb blaster
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stock Exhaust R & R - Suburban 89Suburban Exterior 52 10-15-2016 06:03 PM
Intake Manifold Gasket R & R 89Suburban TBI & EFI Conversions 239 01-29-2011 01:29 AM
Exhaust question? bigchevytruckdriver Tech Discussion 40 01-26-2011 08:12 PM
Exhaust Opinions 89Suburban Engine & Performance 34 12-23-2010 07:09 PM
