Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Tech Discussion
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Tech Discussion Discussion on anything technical or mechanical that doesn't fit in other tech categories.
User Tag List
Reply
Thread Tools Display Modes
Old 07-30-2013, 03:42 PM   #1
CWGRL's Avatar
CWGRL
Year: 1990
Model: V2500
Engine: 350
CWGRL is on a distinguished road
Default 1990 Suburban ECM-1 fuse blows, again & again :-(
I can't find my problem, and I'm going crazy. 1990 V2500, normally run perfect. :-)
On the road last month, and it died. get it home, check fuses... ECM 1 blown. replace..turn key to On position... blows again. sometimes blows on crank.
Before the blow, I could hear fuel pump relay click but no fuel pump prime. I changed the relay and fuel injector relay anyway. still blows.
I have also changed, distrib & cap, rotor, coil. 3 months ago I changed all sensors.
I have traced wiring, everything seems OK. Did the process of elimination with sensors, fuel pump, etc. unplug/plug in... still blows.
What am I missing?
HELP! :-) please Thank you!
CWGRL is offline   Reply With Quote
Old 07-30-2013, 04:01 PM   #2
foamypirate's Avatar
foamypirate
Senior Member
Name: Jake (Mr. Wilson)
Year: 1988
Model: R20
Engine: 6.0L LQ9 - 4L80E
foamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond repute
Default
I can look in my wiring diagram and see what is on that fuse. From there, I would isolate anything that is tied to that circuit, and start checking for shorts to ground with a meter.
foamypirate is offline   Reply With Quote
Old 07-30-2013, 04:18 PM   #3
RetroC10Sport's Avatar
RetroC10Sport
Year: 1967, 1989, 1991, 1991; 1995; 2005
Model: Ford Mustang; GMC Sierra C1500 SportSide, GMC Syclone; Chevy S10 Blazer, Olds Silhouette; Corvette
Engine: 200 L6; 5.7, 4.3, 4.3, 3.8, 6.0
RetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond repute
Default
It goes to the ECM. I would start by unplugging the ECM and cleaning the grounds. The wire that we're looking for is pink/black and goes to the Electronic Spark Control; the gauges; the ECM, the fuel injectors; fuel pump relay.
Does the check engine light come on?
Chengny will know more, I have the wiring diagram available for download though if you'd like.
__________________
"We're gonna get ourselves a cheap lawyer!"
RetroC10Sport is offline   Reply With Quote
Old 07-30-2013, 04:44 PM   #4
CWGRL's Avatar
CWGRL
Year: 1990
Model: V2500
Engine: 350
Default
Thanks everyone for the replies.
Truck isn't throwing any codes... I will check pink/black & ECM...
Old 07-30-2013, 08:04 PM   #5
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Posted from hell
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 08-01-2013, 05:45 PM   #6
CWGRL's Avatar
CWGRL
Year: 1990
Model: V2500
Engine: 350
Default
LMAO...
I have everything unplugged ECM, electronic spark control, map, IAC, etc...
and the damn fuse still blows!
now, I'm going to pull the dash & gauges...
But, could it be in the steering column, lock cylinder?
Old 08-01-2013, 06:06 PM   #7
RetroC10Sport
Default
No, not in the lock cylinder as there's no wiring for it, the ignition switch is down the column a little ways.
You've likely got a pinched wire somewhere or something is shorting out. I my 1991 S10 Blazer, the gages fuse kept blowing because somehow the speedometer wiring got pinched in the transfer case shifter.
1990 Suburban wiring diagram - right click and save as.
__________________
Old 08-01-2013, 06:17 PM   #8
dhamp's Avatar
dhamp
Senior Member
Year: 1987
Model: R-10 Custom Deluxe
Engine: 350
dhamp is on a distinguished road
Default
If you have a voltmeter with a diode tester, many have a beep to show a short. You can put the vm in that mode then probe the feed to each of the items on that fuse until it beeps. If you don't get any shorts, try to slowly move the wires around. Since it's intermittent, you may have to prod it a little to find the short.
dhamp is offline   Reply With Quote
Old 08-01-2013, 06:26 PM   #9
CWGRL's Avatar
CWGRL
Year: 1990
Model: V2500
Engine: 350
Default
Holy Heck! Thank you so much for the diagrams!
You made my day!
Old 08-01-2013, 06:27 PM   #10
RetroC10Sport
Default
You're very welcome.
__________________
Old 08-01-2013, 06:32 PM   #11
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Model: K10 Suburban Silverado
Engine: 5.7 TBI
Jims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud of
Default
Unplug the downshift relay as well...I am assuming you have a TH400 3speed trans. its the relay next to the fuel pump relay on the firewall.
Jims86 is offline   Reply With Quote
Old 08-01-2013, 10:10 PM   #12
CWGRL's Avatar
CWGRL
Year: 1990
Model: V2500
Engine: 350
Default
:-( The only relays on the firewall are the fuel pump & fuel injector relays.
Would the downshift be somewhere else?
Old 08-01-2013, 11:13 PM   #13
RetroC10Sport
Default
If it has a 700r4 OD trans, it won't have one.
__________________
Old 08-02-2013, 01:46 AM   #14
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Engine: 5.7 TBI
Default
there is no fuel injector relay. just the fuel pump relay, then if it has a similar relay next to it, thats the downshift relay. it has a red, orange, tan/blk, and a purple wire going to it.
its a v2500....if its a 4l80e, we need to make sure we are looking at the right diagrams.
Old 08-02-2013, 01:49 AM   #15
RetroC10Sport
Default
its a v2500
Damn interchange is showing that the V2500 could have a 700r4, but the factory info says otherwise.
See your edit. 4L80E did not come out until 1991. Let me look at the compnine info I have and see what it says, could have been a late year option.
Compnine says no 4 speed auto R or V 2500s. So I get schooled as well!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
89S's 1990 R-1500 Chevy Suburban STOCKER Work Thread 89Suburban Under Construction 1520 10-09-2016 08:46 PM
this blows for that guy!! watch this 86chevyk20 Member Videos 16 06-13-2013 03:50 PM
What on earth is this fuse to? Shawn Electrical & Audio 13 04-11-2013 02:48 PM
1990 Suburban w/Tailgate Tail Pan Repair 90Suburban Exterior 16 11-29-2012 02:34 AM
1990 Suburban 2500...repair and modernization. sandrock Member Photos 15 03-09-2011 01:08 AM
