Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Suspension, Steering & Brakes
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Suspension, Steering & Brakes Brake Repair, Disc Brake Conversions, Suspension Replacement, Steering & Alignment
User Tag List
Reply
Thread Tools Display Modes
Old 02-16-2013, 02:20 PM   #1
McCSquare
Year: 1984
Model: K10
Engine: 350
McCSquare is on a distinguished road
Default Power Steering Belt Adjustment
I've got an 84 K10 that was a 305 and the PO put in a 350 SBC. The main belt looks tight, but the power steering belt is sagging. How do I adjust it?
McCSquare is offline   Reply With Quote
Old 02-16-2013, 02:30 PM   #2
marks86
Senior Member
Year: 1986
Model: K30
Engine: 12v Cummins
marks86 is just really nicemarks86 is just really nicemarks86 is just really nicemarks86 is just really nicemarks86 is just really nice
Default
There are two bolts on eaither side of the power steering pump, you can tell what bolts Im talking about because they both has an adjuster built into the bracket, losen them and take a pry bar and pry I honestly cant remeber if its up or done, that should tighten it up
marks86 is offline   Reply With Quote
Old 02-17-2013, 06:30 AM   #3
chengny's Avatar
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
chengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond repute
Default
The top mounting bolt on the inboard side is the pivot. Loosen that just enough to allow the frame to move but also kind of hold your set point while tightening the others.
To tighten the belt, move the bolt (the one that can slide up and down the slot) in the direction indicated by the red arrow. The bottom inboard bolt is also in a slot and will move inward in the slot.
Be advised however, even with the bracket fully adjusted up and out, the belt that is currently driving the P/S pump may need to be changed to a shorter one.
chengny is offline   Reply With Quote
Old 02-17-2013, 10:11 PM   #4
McCSquare
Year: 1984
Model: K10
Engine: 350
Default
Thanks for the diagram... But I think my engine is missing the adjustment bracket. Or do I have it wrong?
Old 02-17-2013, 10:52 PM   #5
MrMarty51
Senior Member
Year: 1979
Model: 20
Engine: 400
MrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud ofMrMarty51 has much to be proud of
Default
It is missing a bracket.
There should be two studs in the two forwards boltsw of the exhaust manifold,the bracket bolts under nuts screwed onto those studs.The bracket then has a 90* bend in it and there is a slotted hole that the stud of the PS pump goes through.
It wont be complete without that bracket and probably will not hold tension.
What was said about the shorter belt,in a couple of posts before,well,I usually go to a sshort enough belt that I have to stretch it and cheat a bit to get it around trhe pulley,then,after a couple of adjustments it is "Just RIIIIIggght".
MrMarty51 is offline   Reply With Quote
Old 02-18-2013, 10:17 AM   #6
McCSquare
Year: 1984
Model: K10
Engine: 350
Default
Anybody know where I can get this bracket? I didn't see it on RockAuto. I can call some salvage yards I guess.
Old 02-18-2013, 01:21 PM   #7
chengny's Avatar
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
Default
BRACKET. Power Brake Booster. Steering Pump Mounting. .
Stock Code 14101199
Manufacturer VPI
Categories Suspension > Power Steering Pump
Assemblies A/C COMPRESSOR MOUNTING-5.0L V8 (
); STEERING PUMP MOUNTING & LINES (
); STEERING PUMP MOUNTING (
); STEERING PUMP MOUNTING-5.0L V8 (
Your Price $ 36.16
Not well described but that's it - item 3 in the upper image.
Old 02-18-2013, 04:24 PM   #8
McCSquare
Year: 1984
Model: K10
Engine: 350
Default
Thanks for the info!
Where are you getting this stuff from?
Also I was having trouble finding that part, but I think LMC has it here:
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=138
I think the kit with all the hardware might be handy, even if it is a bit more expensive.
Old 02-18-2013, 07:24 PM   #9
chengny's Avatar
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
Default
I would strongly recommend using the OEM brace. There is very little wiggle room between the exhaust manifold and P/S pump, so exact fit is extremely important.
Also, while you are tightening the belt, keep a close eye on sheave/pulley alignment (both angular and offset and on 3 pulleys pump. fan and crank) is critical to belt life. Changing the P/S pump drive belt sucks - so you do not want to do it to often.
Buying that particular part as OEM would be money well spent even if it cost more than the aftermarket assembly. Lots of hardware does not indicate ease of installation or a better final set-up. It's usually the opposite.
And from my experience LMC is fine for some things but not the big and heavy stuff.
I just did a rebuild that included a switchover of all the auxiliaries. I spent about 4 hours bending/twisting the brace and elongating bolt holes with a file before it was done. I still wasn't really satisfied with pulley alignment - and this was all OEM.
Old 02-18-2013, 11:33 PM   #10
McCSquare
Year: 1984
Model: K10
Engine: 350
Default
Ok. I'm sold on OEM parts. I'm looking at the first diagram and I believe that I want the brackets in the lower image. My power steering has two belts on it's pully.
Where do you order yours? A Chevy dealer?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help!! Power steering bakoburban Suspension, Steering & Brakes 13 12-04-2013 01:54 PM
Power Steering quentinc25 Suspension, Steering & Brakes 5 09-14-2012 12:22 PM
Steering Column Adjustment? Erichl504 Suspension, Steering & Brakes 1 07-30-2012 01:30 PM
Power Steering and Power Brakes Not assisting. builtnotbought Suspension, Steering & Brakes 4 03-30-2012 09:42 PM
power steering 78shortandwide Lifted & Off-Road Systems 10 09-12-2011 12:13 AM
