Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Differential & Driveline > Front Diff & Hubs
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 01-25-2013, 05:39 PM   #1
emsherer
Year: 85
Model: 1500
Engine: 350
emsherer is on a distinguished road
Question posi front differential?
I have a 1985 1500
chevy 4x4 with manual front hubs.12 bolt rear end,10 bolt front diffferntial. I want to make this truck unstoppable in snow and mud,mainly snow. Can I put a limited slip posi unit in the front.I know it might be a little mean to steer but the manual hubs will remedy that when I'm not in snow. Any thoughts and part numbers ect .? Thanks
emsherer is offline   Reply With Quote
Old 01-25-2013, 05:51 PM   #2
Kapdin's Avatar
Kapdin
Senior Member
Year: 1977,1979,1984,1987,1988
Model: Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
Engine: 400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
Kapdin is a name known to allKapdin is a name known to allKapdin is a name known to allKapdin is a name known to allKapdin is a name known to allKapdin is a name known to all
Default
http://www.eaton.com/Eaton/ProductsS...als/PCT_338418
__________________
1977 K30, 400ci th400 np203 dana60 14bff 4.10's 9.5/16.5 Silverado.
1979 K20, 350ci th350 np203 dana44 14bff 4.10's 265x75-16's Scottsdale.
Kapdin is offline   Reply With Quote
Old 02-01-2013, 02:07 AM   #3
philjafo's Avatar
philjafo
Senior Member
Year: 1978
Model: k20 scottsdale
Engine: 350/sm465/np205/d44/corp14
philjafo is a jewel in the roughphiljafo is a jewel in the roughphiljafo is a jewel in the roughphiljafo is a jewel in the rough
Default
There's also arb, air actuated locking center section or ox locker, cable actuated locking center section. If the goal is unstoppable, locker is better then limited slip, and in snow and ice a good set of tire chains make a two wheel drive truck with an open diff go though stuff that would scare any 4*4.
philjafo is offline   Reply With Quote
Old 02-01-2013, 07:53 AM   #4
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Yes these options are available as listed above, and also the Auto Lockers like Detroit Locker, where it's locked up all the time, and breaks loose on turns IF needed. Would be a great option in snow. And as you mentioned, it will be a bit tougher to steer. Also with manual hubs, you would have the option to lock in 1 hub and have a 3 wheel drive. 2 in the rear, 1 in the front, and if you got in a pinch, jump out and lock in the other hub. Cheap, easy to istall lunchbox type lockers like Lock Right are also available, but not as durable as a Detroit Locker.
Limited slip is NOT a bad option, but keep in mind, you did say unstoppable. Limited slip is an open differential UNTIL it detects slipping then it locks in the other wheel.
Locker stays locked up and unlocks when it detects a strong bind on the axles like making a turn. Many times, that detection and unlocking is late and makes for noisy and uncomfy less than pefect steering, but will provide good traction.
Air or Cable actuated lockers, once activated by the user, they are locked solid and do not break away on turns at all. They are just like having a spool unless you shut them off. They are also quite pricey.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Differential Breather BigCountry Differential & Driveline 5 12-29-2012 01:00 AM
10 Bolt Posi Strength? lusktommy Differential & Driveline 23 07-21-2012 02:39 PM
New posi unit for the 86 silverado 86silverado Differential & Driveline 6 02-03-2012 01:04 AM
need help identifying a posi unit!!!!!!! speed_demon Differential & Driveline 17 04-04-2011 12:49 AM
