Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance > Diesel 6.2, Conversions Cummins, etc.
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 09-18-2012, 01:20 AM   #1
TexasOutlaw87Cummins's Avatar
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
TexasOutlaw87Cummins will become famous soon enoughTexasOutlaw87Cummins will become famous soon enough
Default another Chevy Cummins swap
ok guys !!! well i joined this site cuz it seems that there's allot of knowledge here . im currently doing a 1993 12v ve injection pump cummins swap ! in to a k30 crew cab dually im not that far but i have allot of it on paper and what i need and how its really going to come together ! i have a you tube channel that ill post some links to and you can email me or what ever ill share as much as i know ! and we can help each other !!!
http://youtu.be/vGgB2bJsqCg
http://youtu.be/ODQ6Aq2Jo0U
__________________
2008 4x4 dodge single cab 6 speed : efi live head studs 66mm silver bullet cp3 : 567/1100 1987 crew cab dually 4x4 ,cummins swap NV4500 , hx35 , pod injectors ,second gen intercooler , 8' lift 37 12.50 mil spec tires ,
TexasOutlaw87Cummins is offline   Reply With Quote
Old 09-18-2012, 01:27 AM   #2
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Model: K10 Suburban Silverado
Engine: 5.7 TBI
Jims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud of
Default
I think the biggest challeng is the front crossmember modification, then once thats done, your home free.
Jims86 is offline   Reply With Quote
Old 09-18-2012, 01:36 AM   #3
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
i already have that taken care of ! i made one and soon as i get some pics of it ill post them up ! TN DIESEL POWER.com has allot of stuff to ! what im worried about in the wiring and the tranny mount and the inter-cooler and what radiator to run ! so im going to get it in there and start pulling that 454 out some time this week or next ! but it should be done with in the next couple months
__________________
Old 09-18-2012, 01:48 AM   #4
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
http://youtu.be/-mHtq-kiNkA
__________________
Old 09-18-2012, 01:55 AM   #5
oneluckypops's Avatar
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Engine: 5.7 Fuel injected Vortec/ 4L80E
oneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of light
Default
from what I understand the cooling system is simple, Ive read that alot of people actually complain about the Bigger radiators being too big and end up switching to a 2 core.
Wiring is only as hard as you make it, i will be glad to help you with any of that if your not to savvy at electrical.
Transmission mount will most likely just be a custom made mount, I had to make 1 for my 4L80E swap in my 85.
Ok gonna check your videos out now.
oneluckypops is offline   Reply With Quote
Old 09-18-2012, 02:07 AM   #6
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
a mount that i copied mine from !! well i read that the get rag mounts holes are about the same ! so yea i might have to but im not that far yet im really in the beginning stages ! but i have most of everything to do the swap !!! but yea ill be hitting you up for the eltrickal !! lol cuz that is magic to me !! lol !
__________________
Old 09-18-2012, 02:13 AM   #7
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
OH !!!! if any one could find me part number for the LH and RH tank sending units for the 6.2l would be awsome thats what im going to use ! there already swapped from each other so there not aerating the suction side ! and whats the differance between the 3 outlet and the 2 outlet ?
__________________
Old 09-18-2012, 02:30 AM   #8
wildcatjason's Avatar
wildcatjason
Senior Member
Year: 1988
Model: suburban
Engine: cummins 3.9 4bt
wildcatjason is on a distinguished road
Default
Use your hot to the distributor for the fuel shut off on the ve pump. The Chevy sensors will fit for the water temp and oil pressure. You need a reducer for the water temp. I would recommend getting the bracket from www.autoworldmt.com if you wanna run you Chevy alternator and AC. Are you running hydroboost? I have a 4bt burb if you need help. Looking to sell it though.
wildcatjason is offline   Reply With Quote
Old 09-18-2012, 02:37 AM   #9
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
yea how did you do the fuel in the tank ? was yours a tbi ? what are the 3 outlets ! ? and what do i do with the rest of the harness ? oil pressure and the water temp check ! and distributor hot check ! i built mine cross memeber for the engine what did you do for the tranny ? did you still use a auto ?
__________________
Old 09-18-2012, 02:46 AM   #10
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
oh and yes im hyrdo boost ! im just going to t the lines in to one return ?
__________________
Old 09-18-2012, 03:02 AM   #11
wildcatjason
Senior Member
Year: 1988
Model: suburban
Default
Yes mine was a tbi. I made my own crossmember. I used hydraulic motor mounts from a taurus to ease up some of the shake for the tranny. I have a 5spd from a 89 ford backing up mine. You will need to pull out your electric fuel pump and throw it in the trash. Take a 3/8 fuel line and extend it all the way to the bottom of your tank on the fuel in and the return. I used the third for venting. If you don't vent it will cause a vacuum and if you don't extend your lines to the bottom it will suck air. Either way it will shut the engine down. The rest of the electrical I just cut and removed what I could. Pulled the computer as well.
Old 09-18-2012, 09:59 AM   #12
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
http://www.youtube.com/watch?v=qlfOb...e_gdata_player
__________________
Old 09-18-2012, 10:12 AM   #13
Senior Member
Year: 87
Model: k 30
Engine: 5.9 cummins
Default
Cool thanks man !!! Well this week end is when I'm starting on pullin the 454 out ! Cuz Im getting the other POS dodge out of my drive way cuz the wife is TRIPPING !! about the junk yard I'm starting at my own house !! But seems my projects are the talk with her friends lol what do I bring home this time !!! Im starting to think I could bring home a girl one night an her not car as much as a nother truck these days !!! Lol but shell never stop me !!!! lol but any ways back on topic !! Do you have any pics of Te teanny mount you built ! Maby I could cut And weld the dodge one ? To be able to mount up ? It mounts on th inside of the crime not bolted to the out side and seems a little stronger than the Chevy one but coule be wrong well I don't k ow I know I got a lot of work to do !! And thanks for the help so far I k ow ongoing to need it !!
__________________
Old 09-18-2012, 12:10 PM   #14
towjoe's Avatar
towjoe
Senior Member
Year: 78,80,81,81,86,88,89
Model: K30's or V3500's
Engine: 6.2, 454
towjoe is a splendid one to beholdtowjoe is a splendid one to beholdtowjoe is a splendid one to beholdtowjoe is a splendid one to beholdtowjoe is a splendid one to beholdtowjoe is a splendid one to behold
Default
My brother done one a few years ago with a 5.9 cummins in a 88 V3500 crewcab dually. He used everything dodge from motor mounts, to radiator, to NV4500, to accesories, to clutch hydraulics. Had the output changed in the 4500 to fit his 205 transfer case. His is a 24 valve converted to 12 valve mechanical. Took him 4 months, but made one sweet ride.
towjoe is offline   Reply With Quote
Old 09-18-2012, 01:16 PM   #15
wildcatjason
Senior Member
Year: 1988
Model: suburban
Default
This is pretty fuzzy but you get the idea. I did this because the 4bt has so much more vibration then the 6er. 2 things I'm going to suggest you may already know. Take all the front clip off to get that engine if not you probably find out you are going to need to give up installing it and take it off anyway. Do the kdp fix while it's out or it will be a ticking time bomb. I didn't and lots of guys don't then they end up with a destroyed timing gear cover or the gears themselves.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
engine swap 78 chevy 350 into a 89 chevy c1500 looking to convert to fuel injection?? jake wells Engine Swaps (Gas) LS, Vortec, LT1 , etc. 16 08-24-2015 10:18 PM
Cummins engine swap? 74blazer Diesel 6.2, Conversions Cummins, etc. 16 02-20-2013 03:32 AM
AC Swap over usar17 Tech Discussion 26 07-01-2012 03:40 PM
4bt Cummins Crew Cab JUSTa350 Member Photos 44 06-18-2012 11:36 AM
Chevy Cummins Swap davbell22602 Diesel 6.2, Conversions Cummins, etc. 0 02-03-2011 11:39 AM
