Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Tech Discussion
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Tech Discussion Discussion on anything technical or mechanical that doesn't fit in other tech categories.
User Tag List
Reply
Thread Tools Display Modes
Old 08-30-2012, 05:43 PM   #1
foamypirate's Avatar
foamypirate
Senior Member
Name: Jake (Mr. Wilson)
Year: 1988
Model: R20
Engine: 6.0L LQ9 - 4L80E
foamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond reputefoamypirate has a reputation beyond repute
Default TBI Vacuum Hoses
Hey guys,
I'm hooking up my vacuum lines on my TBI swap, and had a few questions. Figured since a few of you are TBI, you could probably help out.
The first question I have is on the back of the intake manifold. There is a small silver Hex screwed into the manifold with a vacuum port and hose attached. What does the other end of that hose attach to?
The other is cruise control related. In the cruise control harness, there is a large vacuum hose. Where does that attach to on the engine side? The interior side connects to the brake switch. I thought it connected to the cruise control servo, but it seems too large in diameter.
The next one is on the MAP sensor. I have a vacuum line from the TB to the map sensor, but on the MAP sensor, there is port, but nothing hooked up to it. Should there be something hooked up there or is it open?
The vacuum ball...where does its vacuum line attach?
Last, but not least, the climate control harness coming out by the heater box has a vacuum hose, where does it attach to?
I really wish I had taken more pictures when I tore down my 87, dangit! I looked through my factory manual, but couldn't find anything really.
Thanks!
foamypirate is offline   Reply With Quote
Old 08-30-2012, 05:48 PM   #2
RetroC10Sport's Avatar
RetroC10Sport
Year: 1967, 1989, 1991, 1991; 1995; 2005
Model: Ford Mustang; GMC Sierra C1500 SportSide, GMC Syclone; Chevy S10 Blazer, Olds Silhouette; Corvette
Engine: 200 L6; 5.7, 4.3, 4.3, 3.8, 6.0
RetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond repute
Default
There's two ports on the cruise servo, the larger one is for the large line and the smaller one is of course for the smaller hose getting engine vacuum.
__________________
"We're gonna get ourselves a cheap lawyer!"
RetroC10Sport is offline   Reply With Quote
Old 08-30-2012, 05:49 PM   #3
foamypirate
Senior Member
Year: 1988
Model: R20
Default
Cool, thanks! It just seemed loose on there, so I wasn't sure.
Old 08-30-2012, 06:16 PM   #4
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Model: K10 Suburban Silverado
Engine: 5.7 TBI
Jims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud of
Default
Originally Posted by foamypirate View Post
Hey guys,
I think the vacuum ball is T'ed in with the cruise control servo....or is it the HVAC? Lemme look.
Thanks!
The HVAC hose goes to manifold vacuum, I T it in on my brake booster line.
The MAP line comes from the back of the TB, the egr lin is from the passenger side port on the TB, PCV is the large port in the middle,EVAP is the medium port below the EGR.
There should only be one vac port on your MAP.
Jims86 is offline   Reply With Quote
Old 08-30-2012, 06:23 PM   #5
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Engine: 5.7 TBI
Default
Yup, its teed into the climate control line.
Old 08-30-2012, 06:24 PM   #6
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
My manifold rear fitting has a hose coming out, then a check valve, then a T splitting off to the ac/heater and CC/vacuum ball.
MAP sensor should have one line. Are you sure you are not referring to the EGR control valve? That has a vent port and 2 vacuum lines.
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 08-30-2012, 06:26 PM   #7
89Suburban's Avatar
Model: R-1500
Default
And my brake vacuum line feeds off the front/right of the throttle body.
__________________
Old 08-30-2012, 06:53 PM   #8
foamypirate
Senior Member
Year: 1988
Model: R20
Default
Thanks guys! That's exactly what I needed.
89S, you are right, it was the EGR control valve. I was working from memory, and for some reason thought it was MAP.
Old 08-30-2012, 07:12 PM   #9
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Engine: 5.7 TBI
Default
That would be funny as shit....hook up the map sensor wrong, start it, and he comes back posting that his 84 is rolling coal.
Old 08-30-2012, 07:15 PM   #10
89Suburban's Avatar
Model: R-1500
Default
Jims86 taught me.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A/C hoses fowjacob Tech Discussion 5 09-11-2012 09:14 PM
Need help with custom A/C hoses. oneluckypops Engine & Performance 4 05-28-2012 12:48 PM
front brake hoses suck Swims350 Tech Discussion 10 08-13-2011 11:21 AM
Vacuum Question marks86 Engine & Performance 27 02-04-2011 01:18 AM
Vacuum canister.. nxtlevl Tech Discussion 4 11-13-2010 11:49 PM
