Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Transmission & Transfer Case > Automatic Transmission
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 08-01-2012, 08:08 PM   #1
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default GM Automatic Transmission Diagrams
I found some PDF files recently for different transmissions and related parts and thought I should share them here with everyone! Click each for the link, hope they can come in handy.
TH350-350C Exploded View
TCS Products TH350 Schematic
TH350 Pump Port Diagram
TH350 Valve Body Exploded View
TH400 Exploded View (TCS Products)
700R4 and 4L60e Exploded view (TCS Products)
GM Powerglide Exploded View (TCS Products)
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Reply
Bookmarks
Tags
4l60e diagram, 700r4 diagram, gm powerglide diagram, th350 diagram, th400 diagram
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
4speed to automatic coreys87 Transmission & Transfer Case 50 11-30-2013 01:45 AM
Complete 73-87 Wiring Diagrams 82chevy350 Electrical & Audio 1 09-03-2012 05:39 PM
Need Wiring Diagrams davbell22602 Electrical & Audio 0 01-12-2012 07:40 PM
Beware of Automatic Transmission Fluid Additives davbell22602 Tech Discussion 1 01-18-2011 07:40 PM
