Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Tech Discussion
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Tech Discussion Discussion on anything technical or mechanical that doesn't fit in other tech categories.
User Tag List
Reply
Thread Tools Display Modes
Old 05-28-2012, 02:56 PM   #1
Reincarnation83's Avatar
Reincarnation83
Year: 83, 87
Model: C10 Longbed, R10 Shorty
Engine: 355, 350
Reincarnation83 is on a distinguished road
Question 79 lwb stepside bed and frame shorten
Does anyone have any info on where to make the cuts to shorten a longbed stepside body? Any info on this would be a big help.
Reincarnation83 is offline   Reply With Quote
Old 05-28-2012, 03:58 PM   #2
bucket's Avatar
Year: '77, '79, '84, '88
Model: K5, K30, C10, K20 Burb
Engine: 350-454
bucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond repute
Default
You would have to shorten it in front of the fenders and then also behind the fenders, you can't just take it all out in one spot. Sounds like more trouble than it's worth to me. Why not just sell the bed and then buy a short bed?
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
"Faster horses, younger women, older whisky, more money"
bucket is offline   Reply With Quote
Old 05-28-2012, 04:42 PM   #3
Reincarnation83
Year: 83, 87
Engine: 355, 350
Default
Yeah I know that would be alot easier, but I have a feeling these longbed stepsides are not a top choice of bodys for people to buy haha.. Im up for a challenge anyway so if anyone has the exact measurements of where to cut and how much to cut out from each side of the fenders ill give it a shot.. If no one knows the measurements then I will go to my plan B.. I am pretty sure that a regular longbed body would bolt right on to that frame, if anyone knows if that is true let me know and Ill just go that route for now. Thanks
Old 05-28-2012, 07:23 PM   #4
bucket's Avatar
Engine: 350-454
Default
You would be surprised, there's people out there that like the long stepsides. I'm one of them.
A regular longbed will bolt right on in place of it. The filler opening doesn't even have to be on the correct side because the tanks, brackets, and senders can work on either side of the truck.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 05-28-2012, 07:34 PM   #5
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
To the right person that bed will be gold if it is in good shape. If I were you I would just rock it. Otherwise run an ad for swap for fleetside OEV.
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Old 05-28-2012, 08:04 PM   #6
Old77's Avatar
Senior Member
Year: 1977/1987
Model: C10 longbed/R20 Burb
Engine: 350/454
Old77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond repute
Default
X2!!!! Long bed step sides are on the rare side these days especially in good shape!
__________________
**I hope you enjoy the randomly placed trees and poles in each of my pics **
Click for '77 Build Thread
Click for '87 Build Thread
Click for GMT800 Seat Mod Thread
Instagram: 07burb
Old77 is offline   Reply With Quote
Old 05-28-2012, 09:20 PM   #7
Reincarnation83
Year: 83, 87
Engine: 355, 350
Default
Thanks guys Ill list it and see if I get any bites for a possible trade..
Old 05-28-2012, 11:05 PM   #8
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Swims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to behold
Default
yea long bed steps sides I've only seen like 2 or 3 in my life and online only but a guy local has a complete stepside bed long bed for sale.
honestly I think a stepside would be easy to chop down, it's flat on both sides, cut the front and trim the step, then cut the back, then bolt on the fender, leave that area all in tact.
a fleetside bed tapers up in the back making it a real pain and the front is flat and easy. I saw a guy on another forum do a fleetside bed.
I truely think, haven't seen a stepside in person to compare that closely, but I think it'd be tons easier. You can move and redrill the cross sills to make them work as well.
The frame seems pretty easy, flat part behind the cab like 12 or 14 inches there and then move the back crossmember up? and cut off like 4 inches on the back of the frame from what I've seen. it's also on another forum, both on the same one I think.
__________________
FINALLY in a GMSB
Swims350 is offline   Reply With Quote
Old 05-29-2012, 02:26 AM   #9
Reincarnation83
Year: 83, 87
Engine: 355, 350
Thumbs up
Thanks for the info man!
Old 06-09-2012, 11:19 AM   #10
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Oh damn, there is a stepside long beds for Squares??? I knew they existed but rare for 67-72 but have never ever seen a long bed stepside for a square. By no means would I butcher that up. I build with it and rock it. That would be cool as hell.
BTW, welcome to GMSB Matt. I was just looking at your album of the burnt truck. I'd like to see a thread with pics telling that story of the reincarnation of the 83 Scottsdale.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 06-09-2012, 11:22 AM   #11
HotRodPC's Avatar
Year: 85
Default
I'm not a stepside fan at all, but I'd damn sure like to have one of those just for the rarity of it. Got any pics of it on a truck??? I have an almost perfect long bed that is 98% rust free that I'd trade in a heartbeat if you were closer to OKC.
__________________
UNDER CONSTRUCTION
Old 06-09-2012, 04:09 PM   #12
bucket's Avatar
Engine: 350-454
Default
There seems to be lots of the long steps in Ohio, probably just as many of them as the short steps. A few years ago there was an '80 long step C10 at the local pick-n-pull, it had factory installed bucket seats and console too. Now that was an uncommon truck.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 06-09-2012, 04:15 PM   #13
smurph20's Avatar
smurph20
Senior Member
Year: 1986
Model: K20
Engine: 350/SM465/NP208/4.10's
smurph20 is a name known to allsmurph20 is a name known to allsmurph20 is a name known to allsmurph20 is a name known to allsmurph20 is a name known to allsmurph20 is a name known to all
Default
There is a long stepside here in town where i live. Poor thing is beat to hell but he drives it everywhere. Its a 4x4 too has the factory toolbox on the left side step area
smurph20 is offline   Reply With Quote
Old 06-09-2012, 05:04 PM   #14
bucket's Avatar
Engine: 350-454
Default
Huh? Factory toolbox on a stepside?! Can you get a pic of it sometime? I really wanna see it!
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 06-09-2012, 05:33 PM   #15
HotRodPC's Avatar
Year: 85
Default
Do me favor if you would Andy. Next time you see one, snag a pic of it for me. I swear, I don't recall EVER seeing one on a square. As said, I don't care for Stepsides, prolly cuz I don't care for shortbeds, but I want a long stepside. Just cuz it's rare. I'd sure trade a good condition fleetside for one of equal condition for someone who don't like it. I probably won't like it either, but I want it cuz it's rare. I've seen plenty of fleetsides, want to be a bit different.
__________________
UNDER CONSTRUCTION
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
84 stepside frame off build belowaveragecustoms Under Construction 250 01-22-2015 09:49 PM
canadian 76 c10 stepside thatcanuckguy Under Construction 26 12-06-2013 08:36 PM
racing a stepside?? bbc Engine & Performance 26 07-03-2012 11:13 PM
83 stepside wood bed kit? bbc Exterior 1 03-29-2012 10:35 AM
New member with a 74 Stepside 74chevy10 Introduction 11 10-25-2011 10:42 PM
