Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Electrical & Audio > Gauge, Speedo & Instrumentation
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 02-27-2012, 07:59 PM   #1
82chevy350's Avatar
82chevy350
Senior Member
Year: 1982, 1976
Model: C10, K10, K5
Engine: 350, 350
82chevy350 is just really nice82chevy350 is just really nice82chevy350 is just really nice82chevy350 is just really nice
Default Fuel Guage Pegged
On my 76 the Fuel gauge pegged out past full.
When i turn the truck on i can see the gauge move a hair but when i shut it off nothing happens..
I can bang on the dash repeatedly and the gauge will move more towards where it should be.
But when i turn it on again it pegs out.
Bad Ground?
Bad Gauge?
Sending unit?
__________________
Drive It Like Ya Stole It
-SnowBall
'82 Primer White c10 2wd LWB 350 sbc t350
(In The Works) - 383 Build
-Brownie
'76 K10 Custom Deluxe LWB 350 with 305 HO heads/T350 NP203, 4 inch lift, 32x11.50 Tires
(Daily Driver)
'78 Jimmy 4x4 (Play Toy)
(Toys)
'96 Polaris Trailblazer 250 2 stroke
'00 Murray Widebody Racing Mower 12.5 Hp Briggs 55mph
'01 Yamaha Blaster 200cc 2 Stroke
82chevy350 is offline   Reply With Quote
Old 02-27-2012, 08:04 PM   #2
oneluckypops's Avatar
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Engine: 5.7 Fuel injected Vortec/ 4L80E
oneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of light
Default
Bad Ground?
Bad Gauge?
Sending unit?
printed circuit borad would be the first thing i would check
oneluckypops is offline   Reply With Quote
Old 02-27-2012, 09:07 PM   #3
Tyger13us
Senior Member
Year: 78
Model: k10
Engine: 425hp/357cid
Tyger13us has a spectacular aura aboutTyger13us has a spectacular aura about
Default
Bad Ground?
Bad Gauge?
Sending unit?
when my truck does that its always a bad connection where the gauge wire connects to the tank sending unit.
if its not there next thing i would look into would be the sending unit in the tank..
im guessing it a single tank setup......
Tyger13us is offline   Reply With Quote
Old 02-28-2012, 02:39 PM   #4
bucket's Avatar
Year: '77, '79, '84, '88
Model: K5, K30, C10, K20 Burb
Engine: 350-454
bucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond repute
Default
My '79 had all sorts of fuel gauge problems when I bought it, it has dual tanks. First, the valve did not switch but it was just a bad fuse. The gauge didn't work at all either, put in a new gauge and it was then pegged way past full. Found a rubber harness plug was undone at the firewall... connected it and the gauge worked for the passenger tank. The driver side tank still read way past full, but it turns out the sender is off a bit and the tank was full. When empty, the gauge still reads 1/4 full.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
"Faster horses, younger women, older whisky, more money"
bucket is offline   Reply With Quote
Old 02-28-2012, 09:47 PM   #5
matthew.w.mickey's Avatar
matthew.w.mickey
Year: 1985
Model: k 20
Engine: 454 bb
matthew.w.mickey is on a distinguished road
Default
Hey both my tanks do that its the sending units in the tank Im still trying ti fix it doesnt help that my truck is my everyday go work for uncle sam rider
matthew.w.mickey is offline   Reply With Quote
Old 02-28-2012, 11:59 PM   #6
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Default
Bad Ground?
Bad Gauge?
Sending unit?
Hello!!!!!!! people read his post the part in red. If it was the sending units banging on the dash would do NOTHING. The problem lyes at eaither 1 of 2 spots 1 the gauge itself or 2 the Printed Circuit board on the back of the cluster.
Old 02-29-2012, 07:11 PM   #7
82chevy350's Avatar
82chevy350
Senior Member
Year: 1982, 1976
Model: C10, K10, K5
Engine: 350, 350
Default
But remember it only moves when the ignition is off but when the ignition is on i can beat on it all day long and it wont move just pegs out..
Now when i turn on it still pegs out but when i turn it off it will go to full mark and stop turn it on again it pegs out..
Im really thinking its a bad gauge.
__________________
-SnowBall
-Brownie
(Daily Driver)
(Toys)
Old 02-29-2012, 07:25 PM   #8
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
Remove the cluster and check the metal clips that hold the fuel gauge to the housing and make the contact between the gauge and printed circuit. Mine was kind of loose once, had to do some scraping with a pocket knife and pinch the clips tighter with pliers. Reassembled and it worked fine after that.
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Old 03-01-2012, 11:29 AM   #9
bucket's Avatar
Engine: 350-454
Default
Not really. Banging on the dash will often cause even a good working fuel gauge to wander around a bit. Gauge pegged past full is a loss of ground, and with the age of these trucks loss of ground is usually (notice I didn't say always) caused by the ground wire from the sending unit. It will either be corroded right off, or the eyelet needs scraped clean where it bolts to the top of the frame rail.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 03-01-2012, 04:14 PM   #10
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Default
Rather the gauge will move or not is NOT the issue. The reason I said to start with the gauge and or circuit board, is the same principal as if you were to jiggle the ground wire at the tank. If the Gauge started fluxuating from jiggling the wire back there common sense tells you to start there. Its the same thing when you bang on the dash, you are jarring either the gauge itself, the circuit board, or even the connector for the instrument cluster.
Old 03-01-2012, 04:29 PM   #11
bucket's Avatar
Engine: 350-454
Default
I get what you are saying, I just don't think it's as obvious as a clue as you do.
One other thing I forgot to mention. The ground on the printed circuit snakes around all over the place, so when there's a bad spot, it usually makes a bunch of stuff go wacky, not just one gauge.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 03-01-2012, 07:39 PM   #12
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Default
uh i dont think that i totally correct. I could be wrong, but I was THINKING if memory serves me correct the fuel gauge should lave 3 terminals, Power, Ground, and a signal wire (which is also ground) If the signal wire is the loose ground then no it will NOT effect any other gauges as it is not a common ground. Now if its a power or the other ground wire it would entirely depend on how the circuits run and where they enter the fuel gauge to know for sure which ones would be Inop.
Old 03-01-2012, 10:54 PM   #13
82chevy350's Avatar
82chevy350
Senior Member
Year: 1982, 1976
Model: C10, K10, K5
Engine: 350, 350
Default
ok so now with the truck off the gauge is pegged but i can pull my parking lights on and it will go to the correct level.
__________________
-SnowBall
-Brownie
(Daily Driver)
(Toys)
Old 03-01-2012, 11:22 PM   #14
bucket's Avatar
Engine: 350-454
Default
I think we were on the same page, more or less. I just wanted to point out that banging on the dash will often make even a good gauge flicker a little.
Now that right there certainly makes it sound like the printed circuit is the issue.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
Old 03-02-2012, 10:53 AM   #15
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Default
The negative that loops all the way around the circuit should have a black wire connection at both ends, so that if it breaks in one place in the middle somewhere only one or even no gauges/lights will be affected.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Diagnose Engine Problems w Vac Guage HotRodPC Engine & Performance 30 10-16-2015 07:37 PM
Gas tank not taking fuel....WTF?? Bagged Dually Engine & Performance 5 03-08-2012 11:47 AM
Not getting fuel to engine help 1986k10 Tech Discussion 6 02-12-2012 01:39 AM
fuel pump jt1200r Tech Discussion 20 08-25-2011 10:54 AM
87 R10 guage cluster going crazy jake wells Gauge, Speedo & Instrumentation 6 11-06-2010 03:20 PM
