Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Transmission & Transfer Case > Automatic Transmission
Become a Supporting Member         Become a Preferred Vendor
Advertisements
User Tag List
Reply
Thread Tools Display Modes
Old 02-25-2012, 06:09 PM   #1
RetroC10Sport's Avatar
RetroC10Sport
Year: 1967, 1989, 1991, 1991; 1995; 2005
Model: Ford Mustang; GMC Sierra C1500 SportSide, GMC Syclone; Chevy S10 Blazer, Olds Silhouette; Corvette
Engine: 200 L6; 5.7, 4.3, 4.3, 3.8, 6.0
RetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond repute
Default 700r4 not shifting right - WTF?
Okay...I got this 1993 700r4 in my 1981 C10. I hooked up everything right. I am using a TBI TV cable instead of a carb TV cable. I am also using a vacuum switch from a 1985 Suburban and it's wired up correctly.
First and second are fine...Shift into third and it just revs up barely moving. WTF? This is SAME SHIT that the T400 did! I shift it back into second and it goes fine.
I don't have the speedometer hooked up yet.
Do I need to go get the carb TV cable?
__________________
"We're gonna get ourselves a cheap lawyer!"
RetroC10Sport is offline   Reply With Quote
Old 02-25-2012, 07:25 PM   #2
RetroC10Sport
Default
From what i am reading, the 3/4 clutches are burned...Though it shifted fine when I tested it in the Surburban before it was pulled? WTF?
__________________
Old 02-25-2012, 07:49 PM   #3
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
Nah, wait for some of the trans guys to respond bro, if it ran fine when you test drove it it should run fine now unless ya got swindled or something is not hooked up right. Shame there aint a way you could have marked it or something so you know it's the same tranny. I bet it's something simple, I hope.
Where is that wind bag, trans guru HRPC when ya need him, lolz.....
What about the shifter, did ya switch in the OD shifter on the column?
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 02-25-2012, 08:46 PM   #4
RetroC10Sport
Default
Fuck it...It's just a money pit...Money I can use elsewhere.
__________________
Old 02-25-2012, 09:09 PM   #5
oneluckypops's Avatar
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Engine: 5.7 Fuel injected Vortec/ 4L80E
oneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of light
Default
When you swapped the Transmission did you change the filter and fluid? or even just the fluid for that matter? It would apear it is a high mileage Transmission, and the older fluid that was broken down or additives installed has been changed and the problem was most likely there when you test drove it just disgused.
Dont get discouraged even if you need a rebuild, you are HIGHLY capabale of doing it yourself, along with HR and I if there is any problems you will be covered?
oneluckypops is offline   Reply With Quote
Old 02-25-2012, 09:11 PM   #6
RetroC10Sport
Default
Fluid was clean, the trans had been rebuilt before the engine spun a bearing. And yes, I did change the filter as well as putting in synthetic fluid.
__________________
Old 02-25-2012, 10:25 PM   #7
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Just for the fugg of it. Unplug the 4 wire connector and go for a drive. All that should control is lock up, but lock up can affect the 3-4 valve. Still no results, try backing off the TV cable. Let Us know.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 02-25-2012, 10:37 PM   #8
HotRodPC's Avatar
Year: 85
Default
Ohhhh and synthetic fluid??? If the 3-4 clutch pack seals are the least bit dried or have been previously overheated, that fluid just might be to thin. If you're 100% certain its a good trans, and pulling the the 4 wire plug and letting off the TV cable don't work, then I'd think the synthetic fluid might be the issue. And if the syn fluid is the issue, then that tells you, the trans is ailing and that 3-4 pack hasn't got much life left.
__________________
UNDER CONSTRUCTION
Old 02-25-2012, 11:04 PM   #9
RetroC10Sport
Default
I did that...No change. It starts slipping just before shifting into third...
__________________
Old 02-26-2012, 12:45 AM   #10
89Suburban's Avatar
Model: R-1500
Default
The synthetic did it in.
__________________
Old 02-26-2012, 12:46 AM   #11
RetroC10Sport
Default
Dammit Jim! (just kidding, i am not blaming you.)
__________________
Old 02-26-2012, 01:45 AM   #12
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Model: K10 Suburban Silverado
Engine: 5.7 TBI
Jims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud ofJims86 has much to be proud of
Default
What synthetic did you use? Did you install the TV cable before or after the trans was in. I know you have probably checked, but are you sure the TV cable is still connected down at the trans?
Jims86 is offline   Reply With Quote
Old 02-26-2012, 01:50 AM   #13
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Engine: 5.7 TBI
Default
Doesnt he need to shorten the cable? More line pressure may help blow some shit outta the system. If he backs it off any more than the intitial hand WOT setting that will burn it up for sure.
And if it was recently rebuilt, it may have already had a synthetic in it.
Old 02-26-2012, 02:13 AM   #14
RetroC10Sport
Default
Mobile 1
Before. With the correct carb and bracket.
Yes, I did check that first thing.
__________________
Old 02-26-2012, 02:50 AM   #15
Jims86's Avatar
Jims86
Senior Member
Year: 1986
Engine: 5.7 TBI
Default
Hmmm....how many quarts did it take?
I just have a hard time wrapping my brain around why its doing this after 3rd worked just fine in the heavier truck...gotta be some shit in the system somewhere.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
700r4 shifting wagonman Automatic Transmission 4 02-13-2012 08:21 PM
1982 700R4 help no OD 1983_SB_4X4 Automatic Transmission 15 01-23-2012 09:16 PM
700R4 tranny garettjaxx Automatic Transmission 20 01-23-2012 08:40 PM
700R4 help 1983_SB_4X4 Automatic Transmission 10 01-23-2012 03:17 AM
Shifting trans in gear Blackdog3 Transmission & Transfer Case 2 12-15-2011 10:54 PM
