| Tech Discussion Discussion on anything technical or mechanical that doesn't fit in other tech categories. |
10-02-2011, 05:28 PM
#1
Senior Member
Year: 1985/1977
Model: Silverado/c-10
Engine: 350/350
death shake or death rattle???
what is the death shake or death rattle ive heard yall talk about , and what causes it?? i think the 77 might have it and need more info ??
__________________
1985 k-10 350/350/ 33x.12.50( project)
1977 C-10 350/350/ stockers(project)
" better to have it and not need it, that to need it and not have it" Cpt.Call lonesome dove
10-02-2011, 05:33 PM
#2
Year: 1985
Model: K-1500 High Sierra
Engine: 305
In the motorcycle world its the same thing as a tank slapper.
__________________
Proud of my big dumbo mirrors
RetroC10sport: "Yeah, and if my aunt had a dick, she'd be my uncle." Got in my blazer and drove off.
RetroC10sport: "I know a gurl that looks like that...She has a bigger dick than you do."
10-02-2011, 07:44 PM
#3
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
Death wobble is mostly in kingpin front axles like Dana 60. If your C-10 has it I would be looking at the standard stuff, particularly balljoints, but also look at the tie rod ends wheel bearing, etc.
__________________
Montani Semper Liberi77 SWB K10 - 38x12.5-15 TSLs on Eaton 15x10s up front - 6" Front Superlift Springs/Rear ORD Shackle Flip
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles & Grease Bolts All-Around
38.5x14.5-15 TSL SXs on Eaton 15x10s out back - Ramsey REP8000 - TH350 trans with NP205 transfer case
10-02-2011, 08:37 PM
#4
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI / 4L60E
Ahahahahhahah.
__________________
11-28-2011, 07:16 PM
#5
Year: 1988
Model: 2500
Engine: 350
I had some balljoints going bad and that truck would get a wobble goning and scare the SHIP out of you. Check them out real good.
11-28-2011, 11:51 PM
#6
Year: 1986
Model: k3500
Engine: 6.5l twin turbo
if your steering stabilizer shock is bad that truck will shake like a SOB.
i had an 84 chevy dump that did that. thought the body was gonna fall off the truck
__________________
"If it don't Smoke, It's Broke"
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
