Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Exterior
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Exterior Tires, Wheels, Paint, Mirrors, Badges, etc.
User Tag List
Reply
Thread Tools Display Modes
Old 09-28-2011, 04:46 AM   #1
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Question 81-91 Front Clip Removal
Does anyone have a body manual for an 81-91 front clip removal and the bolt locations? I want to remove a front clip in its entirety, but all in one piece with exception of the hood.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 09-29-2011, 03:01 AM   #2
HotRodPC's Avatar
Year: 85
Default
24 Views and noone knows???
__________________
UNDER CONSTRUCTION
Old 09-29-2011, 09:10 AM   #3
Old77's Avatar
Senior Member
Year: 1977/1987
Model: C10 longbed/R20 Burb
Engine: 350/454
Old77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond reputeOld77 has a reputation beyond repute
Default
No documentation but it'd be pretty easy I'd think there's three or four bolts per side near the cab, unbolt from the inner fenders, unbolt from the core support and shizam front clip off...
__________________
**I hope you enjoy the randomly placed trees and poles in each of my pics **
Click for '77 Build Thread
Click for '87 Build Thread
Click for GMT800 Seat Mod Thread
Instagram: 07burb
Old77 is offline   Reply With Quote
Old 09-29-2011, 10:03 AM   #4
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
4 fender bolts on each side at the cab... 1 on top, 1 in where the door hinges are, 1 in the fender well with a big washer on it, and 1 at the bottom of the fender at the rocker panel. Then you have the 2 radiator support mounts, unhook the wiring harness from the headlights, turn signals, marker lights and horns (I think that's all) then take the whole thing off with the fender wells attached. I'm pretty sure that's all there is to it. You might wanna take the battery out to make it lighter, but you'd probably have to do that anyway to get to the light harness.
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Old 09-29-2011, 10:49 AM   #5
J Knight's Avatar
J Knight
Senior Member
Year: 82 Chevy
Model: C10
Engine: 350ci
J Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond reputeJ Knight has a reputation beyond repute
Default
X2 just don't forget to take the hood off first.
__________________
Be Strong
Be of Good Courage
God Bless America
Long Live the Republic
J Knight is offline   Reply With Quote
Old 09-29-2011, 11:48 AM   #6
HotRodPC's Avatar
Year: 85
Default
Thanks dawgs, Sounds easy enough.
__________________
UNDER CONSTRUCTION
Old 09-29-2011, 12:52 PM   #7
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
Here you go with all your detail and crap
__________________
Instagram: 07burb
Old 09-29-2011, 01:07 PM   #8
HotRodPC's Avatar
Year: 85
Default
That's what I was looking for. The detailed info. It doesn't appear there are any hidden screws or bolts according to what he says. Its time for me to start stripping trucks again. I have a bed on 1 truck, the cab off another, and a front clip off another. In my consolidation of projects, I think I am going to be putting the 85C20 cab on the 85K10 frame. Since the VIN is for the 85C20, that's what it will be registered as but will be a 4x4. This is also the truck that I was going to convert to K20 anyway, so it must makes sense. And 85C20 will turn into an 85K20 on a 85K10 frame. In short, nothing more than converting a C20 to a K20. Simple enough huh??? The other good thing, this 85C20 that I've had for 2 years now, is titled in my name, and I just paid the $24 on the plate for a current tag.
__________________
UNDER CONSTRUCTION
Old 09-29-2011, 01:17 PM   #9
J Knight's Avatar
J Knight
Senior Member
Year: 82 Chevy
Model: C10
Engine: 350ci
Default
My neighbor has a truck that is a combination of trucks. We call it Gumbo. Lol
__________________
Be Strong
Be of Good Courage
God Bless America
Old 09-29-2011, 01:34 PM   #10
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
Originally Posted by J Knight View Post
.... just don't forget to take the hood off first.
Really?
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 09-29-2011, 02:33 PM   #11
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
Originally Posted by 89Suburban View Post
Really?
__________________
Instagram: 07burb
Old 09-29-2011, 02:37 PM   #12
89Suburban's Avatar
Model: R-1500
Default
Originally Posted by Old77 View Post
I meant, really, does the hood have to be removed?
I though all the clips I saw on CL had the hood installed on the clip......
__________________
Old 09-29-2011, 02:41 PM   #13
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
oh.... I thought you were....uh.....being silly again....
__________________
Instagram: 07burb
Old 09-29-2011, 02:42 PM   #14
Old77's Avatar
Senior Member
Year: 1977/1987
Engine: 350/454
Default
You could probably actually keep the hood on since the hinges attach to the inner fender. Not sure what it'd do to the hood, though, if the clip twists a little bit upon removal
__________________
Instagram: 07burb
Old 09-29-2011, 02:42 PM   #15
89Suburban's Avatar
Model: R-1500
Default
If I was being silly it would have looked like this:
Really?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dash Removal Question EngineCo.1 Interior 18 08-27-2011 12:09 PM
emission removal Ingram Engine & Performance 43 06-12-2011 12:54 AM
tbi charcoal can removal? Swims350 TBI & EFI Conversions 11 09-05-2010 04:43 AM
Rear window removal Kirk Glass & Mirrors 3 08-24-2010 11:11 AM
