Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Engine & Performance
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Engine & Performance Engines, Engine mods, Chips, Filters, etc.
User Tag List
Reply
Thread Tools Display Modes
Old 05-04-2011, 12:50 PM   #1
jgarner87blazer
Year: 87
Model: K5
Engine: 5.7 350
jgarner87blazer is on a distinguished road
Default 350 idle problems
I have a 87 blazer with a 350 tbi motor. Im having surge problems at idle. I have replaced - O2,TPS, MAP, IAC, temp sensor and dont have any vac leaks.
Its runs pretty good after it warms up but the idle is high at that time. Its driving me crazy and Ive spend a lot of money trying to fix it. I need help. I have read everything on the internet and its the same stuff.
jgarner87blazer is offline   Reply With Quote
Old 05-04-2011, 01:09 PM   #2
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Swims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to beholdSwims350 is a splendid one to behold
Default
check the egr?
__________________
FINALLY in a GMSB
Swims350 is offline   Reply With Quote
Old 05-04-2011, 01:37 PM   #3
89Suburban's Avatar
Year: 1990 Chevy Suburban
Model: R-1500
Engine: 5.7L TBI/700R4/3.73 10 Bolt Auburn L-S /Cat-Back
89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future89Suburban has a brilliant future
Default
There are two temp sensors, you replaced the one on the intake manifold, right?
__________________
1990 CHEVROLET SUBURBAN SPORT WAGON
5.7 TBI/700R4/3.73 10 BOLT AUBURN L/S
TREADWRIGHT ATG's/CAT-BACK/DAILY DRIVEN
89Suburban is offline   Reply With Quote
Old 05-04-2011, 04:09 PM   #4
jgarner87blazer
Year: 87
Model: K5
Engine: 5.7 350
Default
yes i replaced the right sensor. the one in the intske. my mechsnic says the egr has nothing to do with the idle issue.
Old 05-04-2011, 04:21 PM   #5
89Suburban's Avatar
Model: R-1500
Default
I guess if the EGR was sticking opn it would hardly idle, that would be right. Maybe the butterfly isn;t hittin the idle stop, did you try disconnecting the throttle cable and moving the throttle by hand an making sure it is hitting the idle stop?
__________________
Old 05-04-2011, 04:31 PM   #6
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
If you're mechanic tells you, EGR has nothing to do with idle issues, you need a new mechanic.
If an EGR valve gets corroded and dirty with carbon from the exhaust, and it can't close off all the way, then you have an internal vacuum leak. It has everything to do with idle quality.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is offline   Reply With Quote
Old 05-04-2011, 05:03 PM   #7
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Default
x a freakin million.
not to mention if you have a mechanic why would you be neededing to ask about it here? Or anywhere, if he's a mechanic he should be able to figure it out, period. if you're doing it yourself or question him, then by all means ask away.
I had a bad idle in my 88 and it was over the egr being bad. I blocked it off and just deal with the light coming on every now and then.
I hear even new ones have issues, I was told to only replace them with a gm, ac delco or delphi brand, NO OTHER!!!!!!!! They'll act up if you do.
A simple vacuum test will tell if it's leaking or not. Plus not asure on your 87 but my 88 has a vac. solenoid for egr.
__________________
FINALLY in a GMSB
Old 05-04-2011, 05:11 PM   #8
HotRodPC's Avatar
Year: 85
Default
There is 2 reasons to fire the mechanic. #1 he obvioulsy doesn't know what he's talking about, #2, you have GMSB now. FIRE THE MECHANIC !!!
__________________
UNDER CONSTRUCTION
Old 05-04-2011, 05:40 PM   #9
89Suburban's Avatar
Model: R-1500
Default
__________________
Old 05-04-2011, 06:21 PM   #10
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Default
I would agree, I'm sure the guys on here could help you figure out what it is, or tell you what it is. Only thing we can't do is fix it for ya, but if somebody was close enough I bet they might lol.
__________________
FINALLY in a GMSB
Old 05-04-2011, 11:45 PM   #11
bucket's Avatar
Year: '77, '79, '84, '88
Model: K5, K30, C10, K20 Burb
Engine: 350-454
bucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond reputebucket has a reputation beyond repute
Default
Agreed, EGR will cause idle issues. Check for slop in the throttle shaft of the TBI unit. If worn, it can cause intermittent vacuum leaks as well as a binding issue that keeps the throttle from fully closing.
__________________
'77 K5
'79 K30
'84/'78 C10
'88 Suburban
+ a car or two
"Faster horses, younger women, older whisky, more money"
bucket is offline   Reply With Quote
Old 05-06-2011, 12:15 PM   #12
jgarner87blazer
Year: 87
Model: K5
Engine: 5.7 350
Default
Ive tired everything but the egr. How can i block it off. Should I by-pass egr. How is that done?
Old 05-06-2011, 12:22 PM   #13
89Suburban's Avatar
Model: R-1500
Default
Some guys here have done it, made a plate out of tin or something to stick under it.
__________________
Old 05-06-2011, 12:38 PM   #14
Swims350's Avatar
Swims350
Senior Member
Year: 1983
Model: K10
Engine: none
Default
they sell them online and at the local auto parts stores, just ask for an egr block off plate, or I can find the part numbers for you. I think one is made by holley, or wieand and is 9007. You'll need a gasket too they don't come with the plate anymore. ebay has them and so does summit. if you have a hand vacuum pump you can test it and if it doesn't hold vac. it's junk.
One quick way is to just unhook it's vac. line and plug that line with a screw or bolt, or remove it from the carb and put a vac. cap on it. That may help some, but if the egr is carbon'd open and not shutting, it needs removed to fully know if it's the problem.
__________________
FINALLY in a GMSB
Old 05-06-2011, 12:52 PM   #15
89Suburban's Avatar
Model: R-1500
Default
Ok, so a local store should have it, cool.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
700r4 problems marks86 Automatic Transmission 6 04-30-2011 09:09 AM
More th700 problems jetdoc Automatic Transmission 2 04-21-2011 03:40 AM
Electrical problems Manbearpig Electrical & Audio 36 03-16-2011 03:40 AM
Battery Problems in '09 GMC Jaymez Tech Discussion 33 11-19-2010 05:33 PM
Problems 82chevy350 Other Vehicles 47 08-31-2010 01:37 AM
