Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Suspension, Steering & Brakes
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Suspension, Steering & Brakes Brake Repair, Disc Brake Conversions, Suspension Replacement, Steering & Alignment
User Tag List
Reply
Thread Tools Display Modes
Old 04-11-2011, 11:13 PM   #1
Irishman999's Avatar
Irishman999
Senior Member
Year: 1985
Model: K-1500 High Sierra
Engine: 305
Irishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant futureIrishman999 has a brilliant future
Default Wheel bearing replacement.
Step one is getting this locking hub selector off.
Once this cap is off its time to pull all the inside parts.
First thing encountered is a snap ring you have to pull, so far the easiest way to get it out is a razor blade to pry it out of the groove and a flat blade screw driver to work it out.
Once the small ring is out you can pull this aluminum piece out to get to the spanner nuts.
Before the hub assembly comes off you have to pull the caliper off, very simple. Its two long studs that require a large Allen head to remove.
__________________
Member #10.
Proud of my big dumbo mirrors
RetroC10sport: "Yeah, and if my aunt had a dick, she'd be my uncle." Got in my blazer and drove off.
RetroC10sport: "I know a gurl that looks like that...She has a bigger dick than you do."
Irishman999 is offline   Reply With Quote
Old 04-11-2011, 11:23 PM   #2
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
With the caliper off the next step pis removing the spanner nuts that hold the entire assembly on. This requires a special socket I got at Orileys auto for about ten bucks.
The spanner nuts are very important, there is two of them with a keep in between the two nuts. The inner spanner nut has a peg that fits into a keeper with another spanner nut on the outside to hold everything tightly together.
The whole reason for this repair was my inner spanner nut having the peg sheared off for some reason. This let the two spanner nuts back off causing the spindle to move outwards causing problems. i found a new spanner nut with a peg at Orileys for about 10 bucks.
Here is the the parts inside your hub, minus one spanner nut. I could explain how this all goes together but its better to just familiarize yourself with these parts and do one side at a time. If you forget which direction something goes in just take apart the other side as a reference.
__________________
Member #10.
Old 04-11-2011, 11:30 PM   #3
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
After the inside spanner nut is off the whole hub and rotor will slide off of the spindle. At this point I put the whole thing inside of my solvent tank and cleaned all the grease inside and out. If you dont have the luxury just clean it out with a can of brake parts cleaner.
I am doing more of a restoration than a general repair on this truck so I decided to remove this dust shield to clean and paint it. 6 Bolts hold it on the spindle so it was simple to remove so I could clean and paint it.
__________________
Member #10.
Old 04-11-2011, 11:42 PM   #4
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
Now for the technical part, I changed out both inner and outer bearings and the outside race's. I could not find a inside race for sale and suspect they never go bad, the only race that can be trashed is the outside race.
First order of business is the inner wheel seal, old one comes out releasing the inside bearing. Save yourself alot of hassle and spend the ten bucks to get this tool. Its a "seal puller" and it works awesome, 100 times easier than any other method.
Now that the bearings are out its time to get the race pounded out. Once again there is a special set of tools I got to make this a thousand times easier. I picked up this set of drivers from harbor freight for 20 bucks and it was well worth the money.
Pound out the outside race using the correct diameter driver and it will drop out of the outside of the hub, just a few smacks from a hammer should dis lodge it.
Installing the new race is exactly the same just in reverse, take your time and make sure the race is driven in straight. With the driver set its a piece of cake.
At this point I had everything clean so I dropped my whole assembly in the solvent tank, cleaned everything and painted everything in caliper paint.
__________________
Member #10.
Old 04-11-2011, 11:52 PM   #5
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
Next is greasing the two bearings, take your time with this. I got YES another special tool to grease the bearings, this cone device is the shit. You put it in between the two cones and pump the whole thing full of grease with a grease gun, it worked great and was well worth 5 bucks.
Timken bearings.
Here is the greasing setup I used, the most important thing is making sure there is enough grease inside the bearing.
PUT THE INNER BEARING IN FIRST, and then you can install the seal. I usually put a thin layer of silicone on the outside of the seal for extra assurance its not going to leak. Just carefully tap it into place until its flushly in the hub. I will mention again, take your time because if you fuck this up your going to be getting another seal at 5 bucks a pop.
__________________
Member #10.
Old 04-12-2011, 12:03 AM   #6
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
Carefully slide the rotor/hub assembly back onto the spindle and squirt a shit load of grease inside the hub. After its sufficiently full install the inner spanner nut to hold it on.
This part is crucial, you have to set the bearing pre-load. Install the spanner nut with the peg first, with the peg outward. Tighten the nut and turn the spindle by hand until it wont move, after a few times just back the spanner nut off 1/8th of a turn and align the peg with one off the various holes in the keeper.
Once you have the pre load set install the outside spanner nut to lock everything together.
http://s640.photobucket.com/albums/u...ent=HEI101.jpg
__________________
Member #10.
Old 04-12-2011, 12:08 AM   #7
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
After your bearing pre load is set, everything goes back together in reverse order. If you become confused as to the directional orientation of a piece just take apart the other side of your axle as a reference.
At this point you should be good to go, pay attention for sounds after you do this.
__________________
Member #10.
Old 04-12-2011, 12:25 AM   #8
HotRodPC's Avatar
Year: 85
Model: Silverado K10 to K20 Conversion
Engine: 6.2 to Gas???
HotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond reputeHotRodPC has a reputation beyond repute
Send a message via Yahoo to HotRodPC
Default
Nice Write up, I'm sure it'll be reffered to often.
I've been going to do a back brake write up w/ baring removal on a 14b FF rear axle, but didn't take enough pics. Its done very similar to this method too.
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.73 Peg Legger -- http://www.gmsquarebody.com/forum/showthread.php?t=286
85 Chevy Silverado K10 350/700R4/NP208 14FF/10B 4.10 w Lockers --http://www.gmsquarebody.com/forum/showthread.php?t=279
HotRodPC is online now   Reply With Quote
Old 04-12-2011, 12:30 AM   #9
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
Thanks dude, after some more work on the front axle I will be giving the rear 10 bolt some attention.
__________________
Member #10.
Old 04-12-2011, 12:42 AM   #10
RetroC10Sport's Avatar
RetroC10Sport
Year: 1967, 1989, 1991, 1991; 1995; 2005
Model: Ford Mustang; GMC Sierra C1500 SportSide, GMC Syclone; Chevy S10 Blazer, Olds Silhouette; Corvette
Engine: 200 L6; 5.7, 4.3, 4.3, 3.8, 6.0
RetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond reputeRetroC10Sport has a reputation beyond repute
Default
Excellent write up!
__________________
"We're gonna get ourselves a cheap lawyer!"
RetroC10Sport is offline   Reply With Quote
Old 04-12-2011, 12:44 AM   #11
HotRodPC's Avatar
Year: 85
Default
Just glad to see your new found interest in the truck. You were starting to get pretty discouraged with it.
__________________
UNDER CONSTRUCTION
Old 04-12-2011, 01:02 AM   #12
Irishman999
Senior Member
Year: 1985
Engine: 305
Default
The parts washer and square footage to actually do a proper repair made all the difference. Now that I have everything I need its alot of fun, the satisfaction of a job finished is awesome.
I am tackling every little problem with it that drive me crazy one at a time.
__________________
Member #10.
Old 04-12-2011, 01:30 AM   #13
HotRodPC's Avatar
Year: 85
Default
You've got the right idea now.
Also, keep that cheap set of bearing race drivers handly. It also works on some seals, and I bet it will also fit some transmission bushings.
I bought a cheap bushing driver set on sale at HF, same brand as that for like $7.99 or $8.99, and it just so happens to have to the right size driver for small bushings like in the pump shafts, sun gear bushings etc for Th350, 400 and 700r4 transmisisons. So I don't have to carefully use sockets now for those drivers. I fully intend to get that set you got there. One of the things at HF that will probably functions just as well as the high dollar sets. I don't like spending big money on tools to beat on.
http://www.harborfreight.com/bushing...set-38145.html
__________________
UNDER CONSTRUCTION
Old 04-12-2011, 07:51 AM   #14
oneluckypops's Avatar
oneluckypops
Senior Member
Year: 85
Model: K30 SRW
Engine: 5.7 Fuel injected Vortec/ 4L80E
oneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of lightoneluckypops is a glorious beacon of light
Default
Nice job. I hope you dont mind a little constructive critism though.
Theres an easier way of removing the seal WITH OUT a seal puller, infact the method I use doesnt even tear the seal up so if you choose to reuse it you could,
When you take the spanner nuts off slide the outer wheel bearing off, THEN reinstall 1 of the spanner nuts, then grab ahold of the rotor with both hands and pull it off like using a slide hammer, this will remove the inner bearing AND seal,
oneluckypops is offline   Reply With Quote
Old 04-12-2011, 08:33 AM   #15
crazy4offroad's Avatar
crazy4offroad
Senior Member
Year: 1977
Model: One-Ton K-10
Engine: 350/TH350/NP205
crazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud ofcrazy4offroad has much to be proud of
Default
Nice write up, only thing I see is you need IMG tags on the first pic in post #6, as well as mention installing the outer bearing before the spanner nuts. Otherwise great job! (I end up editing posts a million times when I do a write up lol)
__________________
Montani Semper Liberi
77 SWB "ONE-TON K10" - 6" Front Superlift Springs/Rear ORD Shackle Flip 38" TSLs on 15x10s
Welded 14-bolt FF w/Disk Brakes - D60 Front w/ORD X-over Steering, HD Shackles/Grease Bolts
TH350 dual-feed HD trans & NP205 tcase with 32-spline front output mod
79 SWB K10 "Dad's Truck" - Pretty much stock except front push bar, new sliding rear window and bedliner
crazy4offroad is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Buying Replacement parts davbell22602 Tech Discussion 0 02-09-2011 08:13 PM
Battery Replacement 89Suburban Electrical & Audio 5 02-02-2011 08:59 PM
Review: Wheel Bolt Pattern Gauges davbell22602 Garage 2 01-16-2011 07:50 PM
Off Road Wheel HotRodPC Wheels and Tires 10 10-20-2010 11:55 AM
