Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Transmission & Transfer Case > Transfer Case
Become a Supporting Member         Become a Preferred Vendor
Sponsored Ads
Reply
Thread Tools Display Modes
Old 03-25-2011, 02:25 PM   #1
J@meson
Year: 1987
Model: V10
Engine: 350
J@meson is on a distinguished road
Default NP208 shift linkage
Well I believe whats in my truck is the 208, let me begin with that... Now my question is how do I adjust the linkage, Im not getting enough rear pull on the shifter. When I pull it back into 4H I have to pull back on it hard to get the 4 Wheel drive light to illuminate, same goes so that it doesnt pop out when i try to drive it in 4H. In 4L it goes in and operates fine altho a few bumps and griiiiiind and she pops out into neutral. I need to tighten it up a little so that the lever doesnt move when hitting bumps and to get it to stay into gear.
__________________
2002 Trans Am NHRA edition 6spd
1975 Camaro dirt track
1987 Chevy V10 6in lift 35-12.50's
J@meson is offline   Reply With Quote
Old 03-25-2011, 02:43 PM   #2
towman's Avatar
towman
Senior Member
Year: 1987
Model: v10
Engine: 5.0
towman is on a distinguished road
Default
if is the factory one in your 87 it will be a 208, with all the lift you have i assume there is some body lift in there, so make sure the shifter is not hitting the body first, check your motor mounts and trans mounts also, the 208 is known to have troubles popping out of 4 high but check everything before you throw the towel in, that is a very good looking truck you have also
towman is offline   Reply With Quote
Old 03-25-2011, 03:36 PM   #3
J@meson
Year: 1987
Model: V10
Engine: 350
Default
Well as far as I can tell there is no body lift on the truck its all suspension, and the motor mounts and trans mounts are new.
__________________
Old 03-25-2011, 04:03 PM   #4
J@meson
Year: 1987
Model: V10
Engine: 350
Default
And after more searching on google it seems that I have the common worn shift fork problem... I will say its a plus that mine jumps out of 4WD instead of 2WD like I was reading that happens to some...
__________________
Old 03-25-2011, 04:29 PM   #5
towman's Avatar
towman
Senior Member
Year: 1987
Model: v10
Engine: 5.0
Default
i had a blazer that would jump out of 4 high, i had a spare case and put that in, your truck does look real solid but bad body mounts can cause it to
Old 03-25-2011, 11:03 PM   #6
partbirddog
Year: 1985 m1010 cucv
Model: k30
Engine: 6.2 diesel 13k miles
partbirddog is on a distinguished road
Default
i am curious as well, i took out turbo 400 and put it 700 r 4 , having trouble getting enough stroke to shift it(208) on my 1885 k30 , model 60 fr 14 bolt rear detroit locker , real trucks dont have spark plugs 6.2
partbirddog is offline   Reply With Quote
Old 03-25-2011, 11:57 PM   #7
HotRodPC's Avatar
Year: 85
Model: Sierra Classic K1500
Engine: 350/Th350/NP208
HotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud ofHotRodPC has much to be proud of
Send a message via Yahoo to HotRodPC
Default
Nice suttle way of "just throwing that in" about the spark plugs huh pbd???
__________________
UNDER CONSTRUCTION
84 Chevy Silverado C20 454/Turbo 400 14FF 3.21 Peg Legger --> http://www.gmsquarebody.com/forum/showthread.php?t=286
85 GMC Sierra Classic K1500 350/Th350/NP208 10Bolts 3.73's -->http://www.gmsquarebody.com/forum/showthread.php?t=368
85 Chevy Silverado K10 ???/700r4/NP208 10Bolts 3.08's (In Progress) -->http://www.gmsquarebody.com/forum/showthread.php?t=279
85 Chevy Silverado C20 350/700r4 14FF 4.10 (In Progress) -->http://www.gmsquarebody.com/forum/showthread.php?t=294
HotRodPC is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SM465 w NP208 Adapter $100 HotRodPC For Sale 0 01-01-2011 08:36 AM
