Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Interior
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Interior Trim, Seats, Consoles, Door Panels, etc.
User Tag List
Reply
Thread Tools Display Modes
Old 01-27-2016, 05:58 PM   #1
jmcclane55
Year: 1981
Model: C10
Engine: 350
jmcclane55 is on a distinguished road
Default Replacement pad/barrier that goes under the carpet.
While trying to install my speakers, I found the pad under the carpet soaking wet. I pulled it back and I don't think it rusted through luckily. I'll figure out what happened and fix it, but my question is...
The stuff that is ruined, the pad (looks like insulation of some sort) and some type of black vinyl, where do I find replacement for that? On LMC's website, I see sound deadener and heat shield materieal, but doesn't appear to be the same stuff by the looks of it (different color and materials)
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=89
I'm really OCD about things being "correct" so is this what I use to replace my old pad/barrier with?
jmcclane55 is offline   Reply With Quote
Old 01-27-2016, 07:24 PM   #2
yevgenievich
Senior Member
Year: 1991
Model: V2500 burb
Engine: 5.7
yevgenievich is a jewel in the roughyevgenievich is a jewel in the roughyevgenievich is a jewel in the roughyevgenievich is a jewel in the rough
Default
Jute padding. Cut to fit
__________________
1991 GMC V2500 Suburban
1967 Camaro future 305tpi/700r4, past 468 bbc/th350
1989 Trans Am ls1 t56
1994 c3500 350/4l80e
Sold a bunch
Originally Posted by skysurfer View Post
Good rig for robbing banks.
Witness one: "He was in a white Chevy."
Witness two: "You're crazy, it was a blue GMC."
yevgenievich is offline   Reply With Quote
Old 02-05-2016, 09:53 PM   #3
smoothandlow84's Avatar
smoothandlow84
Senior Member
Year: 1984 Frame...87 motor and 700r trans
Model: 1500 r10 pavement scraper
Engine: 350 TBI
smoothandlow84 has a spectacular aura aboutsmoothandlow84 has a spectacular aura about
Default
I used two layers of dynomat. My original pad was roached from age and heat. The original pad does a great job at retaining moisture which can lead to rust. Once you have the carpeting down, no one will ever notice the difference.
__________________
84' Pavement scraper
84 frame, 87 cab, 86 bed, 85 burb doghouse...
BELLY SCRAPER !!!!!!!!!!!!!
smoothandlow84 is offline   Reply With Quote
Old 02-06-2016, 08:29 AM   #4
The reaper's Avatar
The reaper
Senior Member
Year: 84,79,70
Model: Suburban k10, bonanza k10, c10
Engine: 400, 350, 350
The reaper has a spectacular aura aboutThe reaper has a spectacular aura aboutThe reaper has a spectacular aura about
Default
I would just go with sound deadener, it quiets down road noises and tire noises. Check to make sure your heater core isn't leaking and dripping down onto the floor, if it's wet on the passenger side floor
The reaper is offline   Reply With Quote
Old 02-11-2016, 01:19 PM   #5
Jarhead79's Avatar
Jarhead79
Senior Member
Year: 79
Model: 1500
Engine: 350
Jarhead79 will become famous soon enough
Default
Also check behind your kick panels, they love to rust through and allow water to drain into the cab from the cowl area
Jarhead79 is offline   Reply With Quote
Old 05-18-2017, 02:33 PM   #6
mmeth83
Year: 1988
Model: K1500
Engine: 350
mmeth83 is on a distinguished road
Default
https://www.amazon.com/dp/B016QUSBRQ...S7WY71FQ&psc=1
mmeth83 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Carpet replacement richard Interior 2 05-06-2015 01:41 PM
Best carpet richard Interior 6 04-16-2015 11:37 AM
Carpet John81287 Interior 15 01-25-2014 04:33 PM
carpet kit? kleedus Interior 4 10-05-2012 10:52 AM
Carpet Dye HotRodPC Interior 15 10-08-2011 09:25 AM
