Go Back   GM Square Body - 1973 - 1987 GM Truck Forum > '73 - '87 GM Truck Modifications > Differential & Driveline
Become a Supporting Member         Become a Preferred Vendor
Advertisements
Differential & Driveline Front and Rear Axles, Lockers, Limited Slip, Yokes, etc
User Tag List
Reply
Thread Tools Display Modes
Old 05-17-2017, 09:28 PM   #1
Sublime's Avatar
Sublime
Year: 1978/84front clip
Model: K10
Engine: 350
Sublime is on a distinguished road
Default hub temperature
I have an odd question. Has anyone ever read their hubs temperature? I aimed my IR thermometer where you turn them to "free or lock" (warn) and an getting a reading of 145 degrees. Air temp was 80 degrees with normal driving, some stop and starts - no highway driving - about an hours drive.
maybe its me but that seems hot., thoughts?
Sublime is offline   Reply With Quote
Old 05-17-2017, 09:49 PM   #2
Camar068's Avatar
Camar068
Year: 1986
Model: K10/350/700r4/np208/3.08/31"
Engine: 10 yrs Air Force
Camar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of lightCamar068 is a glorious beacon of light
Default
I've often touched mine looking for results of bad bearings with no luck of heat at all. Not sure if that's a good test, but it makes sense to me. Mine are always roughly the same temp as say the outer rim or fender.
__________________
Man....I don't even have an opinion
Oh $h!7 I shot Marvin in the face!
...My name is Paul and this is between Ya'll
Camar068 is offline   Reply With Quote
Old 05-18-2017, 10:03 AM   #3
Sublime's Avatar
Sublime
Model: K10
Engine: 350
Default Sublime
Thanks camaro68, im going to pull the bearings, repack them and tetorque them. Im betting they are to tight
Old 05-18-2017, 11:04 AM   #4
chengny's Avatar
chengny
Senior Member
Year: 1986
Model: K3500
Engine: 350/5.7
chengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond reputechengny has a reputation beyond repute
Default
Originally Posted by Sublime View Post
Thanks camaro68, im going to pull the bearings, repack them and retorque them. Im betting they are to tight
No - don't loosen the bearings. It's never a bad thing to renew the grease. But when you reinstall them, bring the torque right back to where it was.
First off a bearing running at 145 F is not considered hot at all. The general rule of thumb for power plant personnel is - if you can keep your hand on a bearing housing (or the hub in your case) for 10 seconds or longer, it is fine.
Second and maybe more important is the proximity of the hub to the brake disc. When everything made up, they are clamped together to form one combined part (the hub and disc assembly - #57).
Most of the heat generated by braking in stop & go traffic is absorbed by the brake disc.
And since the hub/disc flanges are close coupled, a good percentage of that heat will radiate to the bearing housing section of the hub.
Generally speaking, more bearings are damaged by not being tight enough - rather than being too tight.
Just my thoughts.
chengny is offline   Reply With Quote
Old 05-18-2017, 12:31 PM   #5
Sublime's Avatar
Sublime
Model: K10
Engine: 350
Default Sublime
Just my thoughts.
Thats good info. , thank you
Old 05-18-2017, 02:25 PM   #6
Larry in WNY
Year: 1984
Model: K20
Engine: 5.7 L
Larry in WNY is on a distinguished road
Default
I had a caliper not releasing enough and did as you did checking the rotor temp with IR thermometer. Temp was 145 to 168 on suspect wheel and 110 on the other 3. Told me there was a braking problem. Changing the caliper fixed it. Can't hurt to repack the bearings Also check for brake pad wear and different wear pattern on the rotor.
Larry
Larry in WNY is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A temperature control question CRM Heat & AC 14 07-08-2016 11:10 AM
Temperature Sender Questions CRM Gauge, Speedo & Instrumentation 5 06-18-2016 01:12 PM
Coolant temperature sensor. Jhm89 Tech Discussion 5 08-22-2014 04:03 PM
Automatic Transmisison Temperature HotRodPC Automatic Transmission 11 12-20-2013 04:13 PM
Temperature Gauge Pegs Out sonicbluezx3 Gauge, Speedo & Instrumentation 45 04-11-2013 08:40 PM
